changed timing belt, now have bad idle and code 7 what is wrong
Old Sep 29, 2005 | 06:27 PM
coot_er's Avatar
Default changed timing belt, now have bad idle and code 7 what is wrong
i just pulled my b16 out of my rex to do the water pump and t-belt (also did clutch).
i THINK i did the timing belt right. i lined up the crand and cams and even rotated the crank two turns to check.
when i went to start the engine it started but sounded rough, almost like older cars that have long duration cams. anyhow, i let it go and the idle level out and i thought it was good to go. i backed it up about 20 feet and then it idled to bad i thought it was going to die so i just shut it off. i also have a code 7 (tps).
1.what could be wrong?
2.could a vaccum leak cause the tps code??
3.can i assume i have the cams timed right since it did idle fine for a short time?
Old Sep 29, 2005 | 06:56 PM
coot_er's Avatar
Default Re: changed timing belt, now have bad idle and code 7 what is wrong (coot_er)
any help?
Old Sep 30, 2005 | 07:43 PM
coot_er's Avatar
anyone?
Old Sep 30, 2005 | 07:51 PM
joshb_'s Avatar
if you pulled the motor, then check over your sensor connection and all your vaccum hoses that could very well be the problem
Old Sep 30, 2005 | 08:04 PM
coot_er's Avatar
Default Re: (joshb_)
COULD a vaccum leak cause a TPS CEL?
Old Sep 30, 2005 | 08:06 PM
ghost_ryder35's Avatar
use a timing gun to check your timing. but with the tps code make sure its connected all the way and the connections are clean. also a vaccum leak or a vaccum hose running to the wrong connection could more then definetly cause the problem. when i pulled my motor i hooked it up wrong and it idled at like 100rpms and felt like it was missing on all cylinders. checked the vaccum diagram under the hood switched it around and now all better!
Old Sep 30, 2005 | 08:15 PM
chupacabrah's Avatar
Default Re: changed timing belt, now have bad idle and code 7 what is wrong (ghost_ryder35)
your TPS may have hit on something, and you'd have to recalibrate it.
.5 volt closted throttle, and 4.5 volt WOT. measure voltage on middle wire.
That's what I had to do when i had a code 7.
but also check and make sure you dont have plugs switched or loose or somethin
Old Oct 1, 2005 | 09:58 AM
coot_er's Avatar
Default Re: changed timing belt, now have bad idle and code 7 what is wrong (chupacabrah)
i found the idel problem, i just missed a vaccum line coming out of the throttle body. idles fine now.
still have the tps code though
coilz
Apr 23, 2008 03:51 PM
dabig1(2)
Jan 9, 2006 01:49 PM
gsr2jdm
Jan 15, 2004 09:30 AM
satan_srv
Oct 12, 2003 11:36 PM
tdc
Jul 21, 2002 07:54 PM
