obd2b 2nd o2 heater question.
Old Sep 29, 2005 | 05:18 PM
Slothy's Avatar
Default obd2b 2nd o2 heater question.
Ive searched and havent come up with a define answer, hoping someone here can help me. Car 99cx y7 hatch w/ obd2b y8 head (mini-me). The car works great, just want to loose the cel. There is no cat in the car. I have the 2nd o2 in a pipe on the firewall to trick the ecu into thinking theres cleaner air there. Im throwing a p0141 code: o2 sensor heater circuit malfunction (bank 1 sensor 2). I dont belive the sensor to be bad as it worked up untill i moved it. I guess the question is, can i add a resistor to the line so the ecu sees it as fine. I am planing to get a p28 w/ harness sometime, but would like to get a temp fix untill then.
Cliffs: need to bypass 2nd o2.
Emissions are not relivant here in Nova Scotia so that is not an issue for me.
any help would be great.
Thanks.
Old Sep 29, 2005 | 05:25 PM
specv5150's Avatar
Default Re: obd2b 2nd o2 heater question. (Slothy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slothy &raquo;</TD></TR><TR><TD CLASS="quote">Ive searched and havent come up with a define answer, hoping someone here can help me. Car 99cx y7 hatch w/ obd2b y8 head (mini-me). The car works great, just want to loose the cel. There is no cat in the car. I have the 2nd o2 in a pipe on the firewall to trick the ecu into thinking theres cleaner air there. Im throwing a p0141 code: o2 sensor heater circuit malfunction (bank 1 sensor 2). I dont belive the sensor to be bad as it worked up untill i moved it. I guess the question is, can i add a resistor to the line so the ecu sees it as fine. I am planing to get a p28 w/ harness sometime, but would like to get a temp fix untill then.
Thanks.</TD></TR></TABLE>
Why go through the trouble of wiring resistors and whatnot if you plan to get a P28?
Old Sep 29, 2005 | 05:36 PM
Slothy's Avatar
Default Re: obd2b 2nd o2 heater question. (specv5150)
p28 wont be for a while...winter/ spring area. Looking for a fix untill then.
Thanks.
Old Sep 29, 2005 | 05:55 PM
hatchi's Avatar
why dont you buy an o2 sim to trick the ecu that sensor is there??
Old Sep 29, 2005 | 05:58 PM
Slothy's Avatar
Default Re: obd2b 2nd o2 heater question. (hatchi)
thats the problem, the ecu sees that the sensor is there and working, it just has a problem with the heater control. As far as im aware, the sim doesnt do anything for the heater only the o2.
Old Sep 29, 2005 | 06:08 PM
hatchi's Avatar
did you try to hardwire the heater control ??
Old Sep 29, 2005 | 06:10 PM
Slothy's Avatar
no, still using oem harness. Perhaps the wire is damaged to the ecu. Ill check the ecu @ A9 to see if theres continutity in the morning.
Old Sep 29, 2005 | 06:13 PM
92eg6's Avatar
youll prob still get the code w/a p28, i was gettin, but i used uberdata to take of the cell, but until i got my a/f corrected it gave me crappy gas milage
oh does ne1 know if this has nething to do w/da heat, cause myn sucks
Old Sep 29, 2005 | 06:45 PM
specv5150's Avatar
Default Re: obd2b 2nd o2 heater question. (92eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92eg6 &raquo;</TD></TR><TR><TD CLASS="quote">youll prob still get the code w/a p28, i was gettin, but i used uberdata to take of the cell, but until i got my a/f corrected it gave me crappy gas milage
oh does ne1 know if this has nething to do w/da heat, cause myn sucks</TD></TR></TABLE>
you wont get a 2ndary O2 CEL with a P28
Old Sep 30, 2005 | 02:15 AM
Slothy's Avatar
23mpg city is why im looking into this.
Old Sep 30, 2005 | 05:20 AM
92eg6's Avatar
oh no, i think it was the primary one, 1st wen i had a p72 it was throwin secondary then wen io had a p28 after a little while it threw a primary, but i jus over looked it w/uberdata
boosted civi
Mar 10, 2009 07:15 PM
1point7db2
Dec 26, 2005 08:36 AM
Btothe3rdDegree
Sep 6, 2004 07:11 AM
turbo_civic
Dec 30, 2002 03:27 AM
