98 civic ex...turbo or supercharge
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16y8EL »</TD></TR><TR><TD CLASS="quote">they both boost the car morons.
what they mean is turbo it. lots of info on the site here bud, just use the search button and your good to go.</TD></TR></TABLE>
go BOOOST (that's the turbo boost, the supercharge boost is just "boost")
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philip »</TD></TR><TR><TD CLASS="quote">go BOOOST (that's the turbo boost, the supercharge boost is just "boost")
You can build a turbo setup better with less money than an s/c car, but depending on what kind of turbo/s/c you go with, they have their advantages and disadvantages. Supercharger has instant power, while unless you have a really small turbo, spool up takes at least a split second. Generally low end power with an s/c, while a turbo usually gives better high end power.
-Shane
</TD></TR></TABLE>You can build a turbo setup better with less money than an s/c car, but depending on what kind of turbo/s/c you go with, they have their advantages and disadvantages. Supercharger has instant power, while unless you have a really small turbo, spool up takes at least a split second. Generally low end power with an s/c, while a turbo usually gives better high end power.
-Shane
alperx
Engine Management and Tuning
Oct 24, 2011 08:37 AM
