B16B VTEC solenoid
I can't see on my solenoid where the oil pressure switch goes. Does this motor not require one?
On other b16 solenoids that I've seen the switch was right there but I don't see it on here. And that hole that you see under the bracket doesn't go all the way through.
i have seen a few b16's lately with no pressure switch spot. The location is there but it hasnt been drilled and threaded. Just ground the switch back to the ecu. If the ecu doesnt see it ground you get no Vtec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jameskersten1 »</TD></TR><TR><TD CLASS="quote">i have seen a few b16's lately with no pressure switch spot. The location is there but it hasnt been drilled and threaded. Just ground the switch back to the ecu. If the ecu doesnt see it ground you get no Vtec.</TD></TR></TABLE>
I've read about that and I'll do it as a last resort. This might make a difference, I don't know. The ecu that came with the swap has spoon stickers on it. So, either the previous owner was a ricer or it's a spoon ecu. Could it be that a Spoon ECU doesn't look for a pressure switch at all?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junior40er »</TD></TR><TR><TD CLASS="quote">damn is you radioator hose thingy broken?</TD></TR></TABLE>
Yeah, so was the distributor.
The motor was in a wreck so I got it for super cheap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay »</TD></TR><TR><TD CLASS="quote">I heard that jdm motors don't use an oil pressure switch for their newer vtec motors..I may be wrong though.</TD></TR></TABLE>
I hope this is true. The less wires I have to run through the firewall the better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kouki-EK9 »</TD></TR><TR><TD CLASS="quote">
The motor was in a wreck so I got it for super cheap.</TD></TR></TABLE>
the ecu might not look for the switch but thats not why you dont have a location for the switch. Either way, that is how we have done every swap lately without that switch. No problems yet.
The motor was in a wreck so I got it for super cheap.</TD></TR></TABLE>the ecu might not look for the switch but thats not why you dont have a location for the switch. Either way, that is how we have done every swap lately without that switch. No problems yet.
Cool, I'll try that. Thanks.
</TD></TR></TABLE>Cool, I'll try that. Thanks.
1baddc5
19
Feb 12, 2007 06:14 PM
Takumi Fujiwara
Jul 23, 2006 09:18 PM
Tad
28
Sep 2, 2004 10:04 AM
