Car got slower after installing igniter and coil
Old Sep 29, 2005 | 12:57 PM
Jonovision's Avatar
Default Car got slower after installing igniter and coil
i made sure before i removed my dizzy to marke down where its timed with a pen,when i put it back,car doesnt pull as hard from my friends rsx plus i ran high 14s on my gtech rather than low 14s.Any ideas?
Old Sep 29, 2005 | 12:59 PM
jameskersten1's Avatar
check your timing again. I dont ever trust just marking it. grab a timing gun and do it right
Old Sep 29, 2005 | 01:03 PM
q45mm's Avatar
Default Re: Car got slower after installing igniter and coil (Jonovision)
Put it in Neutrel then give it gas and listen to see if it bogs out or isn't picking up if so you might not have to take the dizzy out just unbolt it slightly and mover it.
hope that helps
Old Sep 29, 2005 | 01:04 PM
peacexisxfree's Avatar
Default Re: (jameskersten1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jameskersten1 &raquo;</TD></TR><TR><TD CLASS="quote">check your timing again. I dont ever trust just marking it. grab a timing gun and do it right</TD></TR></TABLE>
Old Sep 29, 2005 | 01:06 PM
Jonovision's Avatar
Default Re: Car got slower after installing igniter and coil (q45mm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by q45mm &raquo;</TD></TR><TR><TD CLASS="quote">Put it in Neutrel then give it gas and listen to see if it bogs out or isn't picking up if so you might not have to take the dizzy out just unbolt it slightly and mover it.
hope that helps</TD></TR></TABLE>i already removed it cause i fried my old igniter but now it slower,what am i aiming fir with a timing light?.I read the c-speed website but they didnt specify what i should adjuts it to,its an eg with a b18c
Old Sep 29, 2005 | 01:13 PM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonovision &raquo;</TD></TR><TR><TD CLASS="quote">
I read the c-speed website but they didnt specify what i should adjuts it to,its an eg with a b18c</TD></TR></TABLE>
stock b18c timing. i think its 18 degrees before tdc +-2.
Old Sep 29, 2005 | 01:17 PM
q45mm's Avatar
on the crank there is a little tab on it aim it on that set ur timing light and ur good to go. Let me know if u need a pic i got i i just cant host it's from the dealer and they won't let me cut and paste
Old Sep 29, 2005 | 01:40 PM
Jonovision's Avatar
yes a good pic would be awesome,thanks guys
Old Sep 30, 2005 | 04:16 AM
q45mm's Avatar
Here's the pic hope this help.
http://img209.imageshack.us/my...l.png
would post it directly but i just dont know how to.
I guess im retared
Old Sep 30, 2005 | 06:48 AM
Brodie Bruce's Avatar
Default Re: Car got slower after installing igniter and coil (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">
stock b18c timing. i think its 18 degrees before tdc +-2.</TD></TR></TABLE>
16* before TDC +/- 2 actually
ALLmotorTYPES
24
Jul 7, 2007 08:31 AM
Nasty1civic
Jun 23, 2006 12:56 PM
platinum00
Dec 17, 2004 08:53 AM
kaoss_11
10
Aug 22, 2004 06:28 PM
SleepyHF
Mar 23, 2004 05:46 PM
