2Steppin a car
Old Jun 22, 2006 | 03:12 PM
Nasty1civic's Avatar
Default 2Steppin a car
Can someone please explain the 2stepping concept and how to do it please!??
Old Jun 22, 2006 | 03:53 PM
b16sedan's Avatar
Default Re: 2Steppin a car (Nasty1civic)
Just move your hips to the beat of the music, unless you're talking about country, then it's a bit more complicated.
A 2-step pulls a ton of timing and gives you a secondary rev limiter and yanks out a ton of timing so you can have consistent launches and spool a turbo out of the hole.
Old Jun 22, 2006 | 05:01 PM
Default Re: 2Steppin a car (b16sedan)
No I am talkin about in a car.Not dancing example check it out
Click to see Video
Old Jun 22, 2006 | 05:04 PM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16sedan &raquo;</TD></TR><TR><TD CLASS="quote">
A 2-step pulls a ton of timing and gives you a secondary rev limiter and yanks out a ton of timing so you can have consistent launches and spool a turbo out of the hole.</TD></TR></TABLE>
actually antilag is where the timming is pulled to spool the turbo. a straight up 2 step is a secondary rev limiter triggered by a 12 volt source, transbrake, linelock, or on most honda cases like mine, the ebrake. what it does is, fires everyother cylinder or 2 at a time instead of all 4 to hold the engine at a certain predetermined rpm. you can get boost out of it but not as much as you would off of anti lag. i 2 step at 8200 and get about 7 psi. when you launch, drop the ebrake, cutting the 12volts off to the 2 step, putting it onto the primary rev limiter. it is a great thing to help you stage and launch the car. here it is on my car, http://videos.streetfire.net/v...7.htm
Old Jun 22, 2006 | 05:09 PM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nasty1civic &raquo;</TD></TR><TR><TD CLASS="quote">Can someone please explain the 2stepping concept and how to do it please!??</TD></TR></TABLE>
as far as how to do it, you either need an ems with some sort of launch control, or an add on ignition box with a rev limiter input. some hate it but my msd 6al has been working fine.
Old Jun 22, 2006 | 05:35 PM
velocitytrends's Avatar
Default Re: 2Steppin a car (boostedcivicsir)
Great clip, great example and great driving!
Old Jun 22, 2006 | 05:37 PM
Mr. Badwrench
Default Re: 2Steppin a car (velocitytrends)
thanks maeng.
whenever i post that vid i must follow with the disclaimer. The WideBand Died Driving it to the lane In the First Round. It was 11.0 on the dyno so i know it is safe. read the plugs after every pass. i know 14.6 will melt a motor at 27 psi.
Modified by boostedcivicsir at 2:47 AM 6/23/2006
Old Jun 22, 2006 | 05:46 PM
Johnny O A20 KIller's Avatar
What is up with that a/f guage saying you are running a a/f of 14 or so.
Old Jun 22, 2006 | 05:48 PM
Mr. Badwrench
Default Re: (Johnny O A20 KIller)
see above. wideband died before first round of qualifying.
Old Jun 22, 2006 | 06:18 PM
redboost10's Avatar
Default Re: (boostedcivicsir)
this may be a dumb question, but is the 2step usually set at a lower rpm than the primary limiter, right? also, i may be way off, but i thought the purpose of a 2 step is to keep traction in the lower gears, but after reading your post, it sounds like you use it to make boost at the line? sorry to steal the thread.
Old Jun 22, 2006 | 06:21 PM
Mr. Badwrench
Default Re: (tgh99si)
i am not using mine to make boost. it is a pleasent byproduct. i am running a b16 and need wheel speed to get the car moving. on that pass i cut a 1.68 short time. i just use it because i dont want to have to think where the gas pedal is on the launch.
and yes the launch limiiter is lower than the top limiter.
Old Jun 22, 2006 | 06:24 PM
redboost10's Avatar
can you give us some pointers on how to set it at the recommended rpm. why did you pick 8900 rpm? just wondering.
Old Jun 22, 2006 | 06:34 PM
Mr. Badwrench
my launch should be at 8200, thats what my module is set at, my shift rpm is 9400, top rev limit is 9800. when we were on the dyno, my car was still making power at 9800. remember it is a b16.
getting the launch rpm took some time and phenageling with tire pressures. first pass was like 7200 with 9 psi. spun 2.2, then 7200 at 7.5 psi. bog 2.0. then we broke my module but luckilly it broke at 8000. then 8000 at 8 psi spun a little but went 1.85. then at atco, on that pass, 8200 with 7.25 got some vehile speed up but was spinning, but went 1.68. now i will mess with the suspension.
Old Jun 23, 2006 | 07:09 AM
redboost10's Avatar
thank you for the info
Old Jun 23, 2006 | 07:38 AM
k20pinay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by velocitytrends &raquo;</TD></TR><TR><TD CLASS="quote">Great clip, great example and great driving! </TD></TR></TABLE>
x2
Old Jun 23, 2006 | 10:52 AM
jeffsciv23's Avatar
awsome clip.
i have a digital 6 box that i was gonna hook up but i couldn't figure where to hook the 2-step to. i was gonna hook it to a button on the steering wheel but the E brake sound easier. so how exactly are you launching? sounds like a lot of **** to do, let out clutch, drop e brake and step on gas.
Old Jun 23, 2006 | 11:22 AM
Default Re: (jeffsciv23)
Thanx alot ya'll!
Old Jun 23, 2006 | 12:56 PM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeffsciv23 &raquo;</TD></TR><TR><TD CLASS="quote">awsome clip.
i have a digital 6 box that i was gonna hook up but i couldn't figure where to hook the 2-step to. i was gonna hook it to a button on the steering wheel but the E brake sound easier. so how exactly are you launching? sounds like a lot of **** to do, let out clutch, drop e brake and step on gas.</TD></TR></TABLE>
well here is the beauty of the 2 step. your foot is already on the floor. the hardest thing i have found so far is preloading. i think i have got it, but i am still affraid of loosing the preload and lunching the final drive.
since the ebrake switch is a ground, there are only 2 wires out of the step module, 12v and ground. usually you would ground the 2 step and put 12volts to it via a line lock, or tranny brake. just wire it in reverse. run a fused 12v to the 2 step, and the other side goes to the ebrake switch. when it is up, completing the circuit, arming the 2 step. it is a little tricky droping the handle and releasing the clutch, but with a little practice, it isnt that bad. h.t.h.
ALLmotorTYPES
24
Jul 7, 2007 08:31 AM
JDM_rolex
Jul 19, 2006 03:58 AM
Fusion G2 Civic
Jan 5, 2006 04:39 PM
platinum00
Dec 17, 2004 08:53 AM
Sinner
Jul 1, 2004 11:32 AM
