Which Turbo To Use?
Old Sep 29, 2005 | 12:02 PM
onemoreday21's Avatar
Default Which Turbo To Use?
I have a boosted b18b with a t3/t4 setup. I'm usin a s-afc II and an avc-r for boost control. My question is what would be the best turbo to use for quick spool up and around 400 hp max output? Im lookin at a HKS GT2835 but i dont see too many of them around. Also possibly a Turbonetics T3 with a .48 compressor. I'm also looking for full boost around 3000 rpm and good partial throttle boost respone. Right now i'm not spoolin til around 5000rpm and im runnin a 14.86 in 1/4 with slightly slipping clutch and lots of lag. Wanna reach thirteens. Need help
Old Sep 29, 2005 | 12:04 PM
Default Re: Which Turbo To Use? (onemoreday21)
Forgot to add I have avc-r set at .6bar (8.13 psi or sumthin like that)
Old Sep 29, 2005 | 12:06 PM
White Smoke's Avatar
i my honda
Global Mod
t3/to4e is for you
Old Sep 29, 2005 | 12:26 PM
Are you sure? I am willing to sacrifice power output for turbo respone. That is my main goal here. A really really streetable turbo. Not the monstrosity that I am using right now.
Old Sep 29, 2005 | 02:47 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (onemoreday21)
first off.... ditch the safc and get real fuel management.. its a halfass way to do things and you cant control ignition timing, which is what makes power on turbo motors
Old Sep 29, 2005 | 02:52 PM
bnut510's Avatar
Default Re: Which Turbo To Use? (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">t3/to4e is for you </TD></TR></TABLE>
yup
Old Sep 29, 2005 | 05:09 PM
cmyrex's Avatar
Default Re: Which Turbo To Use? (bnut510)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bnut510 &raquo;</TD></TR><TR><TD CLASS="quote">
yup </TD></TR></TABLE>
I agree
Old Sep 29, 2005 | 05:11 PM
cmyrex's Avatar
holly<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onemoreday21 &raquo;</TD></TR><TR><TD CLASS="quote"> Right now i'm not spoolin til around 5000rpm and im runnin a 14.86 in 1/4 with slightly slipping clutch and lots of lag. Wanna reach thirteens. Need help</TD></TR></TABLE>
that turbo is a monstrosity, the t3/t4oe would work good for you
Holly turbo lag BATMAN!!!!!!
Old Sep 29, 2005 | 05:19 PM
TheShodan's Avatar
Moderator
I would actually say either my GT32 spec'd "blue Pill" or my GT3257 "red Pill" for the B18B. It starts positive boost at about 2800 and goes past 8000,
Old Sep 29, 2005 | 09:17 PM
Stop the Beast's Avatar
If your not going to make more than 325whp then check out the GT28RS, and if your going to need more than 325whp check out the GT3071R.
Both by Garrett.
civhatch90
Apr 5, 2005 01:18 PM
crxsir23
Dec 10, 2004 04:28 PM
Dramier
Jan 4, 2003 06:24 AM
LOwrestling2001
Nov 27, 2002 09:59 AM
