Front sway bar question.
Old Mar 2, 2002 | 06:30 PM
HondaIntegraLS's Avatar
Default Front sway bar question.
How do I mount the sway to the chasis on a 93 civic that did not have a factory bar from the factory. I have the Integra front 24mm bar, brackets, endlinks, and front lower control arms. I see most kits like suspension tech come with pieces you need to mount to the chasis and then mount the bar to that. Do I need that? If so where would I get it. I am trying to stay all OEM in the front suspension.
Old Mar 2, 2002 | 08:22 PM
Robster's Avatar
Default Re: Front sway bar question. (HondaCivicCx)
on the front lca, there is a small hole that would be parrelel to the ground, the endlink goes through that hole and the sway bar is connected to the endlink. There are d bushings and brackets that go around the sway bar, the d bracket surrounds the d bushing. The d bushing is then bolted to the bottom of the car with 2 12mm bolts.
Old Mar 3, 2002 | 04:57 AM
Default Re: Front sway bar question. (Robster)
I know about the hole in the control arm, but the under side doesn't look like my integra where it mounts to the chasis (one the car itself)
Thanks
Mike
Old Mar 3, 2002 | 05:41 PM
Robster's Avatar
its in the same part of the subframe for the civics as it is the integra, just look for the 2 holes.
Old Mar 8, 2002 | 01:32 PM
Charles B.'s Avatar
OT a little, but would that sway bar work good with the R rear sway bar on an EG?
Old Mar 8, 2002 | 01:35 PM
mantic6t9's Avatar
Default Re: Front sway bar question. (SuperDuperEG)
I suggest a 19mm rear sway bar for street use.
MattNYC
Jan 22, 2010 10:18 AM
immajackuup
Apr 22, 2009 12:25 PM
User 12720
Suspension & Brakes
Jan 10, 2009 04:20 PM
JMelt4
18
Apr 30, 2007 07:43 PM
NTGR8D
Nov 30, 2003 02:27 PM
