vtec malfunction on gsr???
Old Sep 28, 2005 | 09:33 PM
tuckin15s_8315's Avatar
Default vtec malfunction on gsr???
ok just recently my cel light came on so i ran the code and it says vtec system malfunction.... basically it will not allow vtec to kick in making it impossiable to rev past 5k of course i can reset the ecu but that wouldnt solve the problem only make it go away for a few days any help is much aprreciated i just am not shure where to begin to fix it.. thanks
Old Sep 28, 2005 | 09:59 PM
haitech's Avatar
Default Re: vtec malfunction on gsr??? (tuckin15s_8315)
my friend had a similar problem with his b16 crx. he just change the oil... haha.. i know that sounds stupid but when he change the oil VTEC works. i hope that helps. if not then you might check your vtec solenoid.
Old Sep 28, 2005 | 10:12 PM
triple_s1x's Avatar
Default Re: vtec malfunction on gsr??? (haitech)
Check your oil level, check the screen on the back of the vtec soliniod, and finally just check to make the sure the wiring is all intack.
Vtec works off of oil pressure, if you dont have enough pressue you wont have vtec. Check what i mentioned first and then chime back.
3JP
Jun 7, 2010 10:36 PM
stwokay
May 21, 2009 06:36 PM
gsrboost737
Aug 7, 2008 06:38 AM
B20_SI_CRX
21
Jun 8, 2005 10:03 AM
spoonef
Feb 28, 2003 10:01 AM
