best motor to turbocharge?
Old Mar 2, 2002 | 05:29 PM
ziich's Avatar
Default best motor to turbocharge?
Which B-series motor is best for turbocharging in terms of reliability and potential to create power (given that pistons, rods, injectors, other internals, etc will be upgraded/replaced for the turbo).
Old Mar 2, 2002 | 05:30 PM
DragII's Avatar
25 Year Member
Default Re: best motor to turbocharge? (ziich)
if you are replacing all the internals...it does not matter which motor you choose.
Old Mar 2, 2002 | 06:16 PM
BoM's Avatar
BoM
Default Re: best motor to turbocharge? (DragII)
if your not resleeving a 1.8 is great.
Old Mar 2, 2002 | 06:36 PM
AutoSol's Avatar
New User
That's not an easy question to answer, so many options to go with. I'd say go with whichever one you can find the cheapest (probably B16A or B18A/B). Use the money saved for internals and a good turbo build. I've got a turbo B18B myself, and I'm happy with it (internals are all stock, boosting 6psi).
The theory is that the B16 is the most reliable (re: rod stroke ratio), and it responds well to mods (re: good flowing head). The longer stroke of the B18B (resulting in lower compression) makes it a good candidate for turbocharger "out of the box." The B20B is another good option (being it's a big-bore B18B), though possibly more expensive. Once you start messing with internals, though, it's a different story -- it all depends on what internals you go with and who does the motor buildup.
If this is a daily street driver, and you want something simple, fun, and fast (i.e. 200+whp and not a lot of down time), go for the LS/turbo.
Old Mar 2, 2002 | 06:47 PM
14eight's Avatar
Default Re: best motor to turbocharge? (AutoSol)
i say d16z6, cheap parts, easy to replace, plus its vtec. bam!! peace
abcriderdafa
Nov 27, 2004 05:51 PM
Turbo Sleepers
Oct 19, 2004 10:46 AM
mEr
Oct 26, 2003 09:10 PM
redteg1
Nov 24, 2001 02:58 PM
