IM and TB question
From peoples experience or opinions Whats the best Intake Manifold/Throttle Body combo for a GSR?
does anyone know some advantages to some and maybe some disadvantages to others? I have heard that some IMs only help in the higher 7000 to 10000 rpm range and people actually lose power off the line from these. Skunk2 has a IM that sounds like it helps throughout the entire RPM range but don't quote me on that just have read about it. If I went with that IM and say a 65 or 70mm Edelbrock TB would that be a good way to go or should I go with a JDM Type R TB
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stivic »</TD></TR><TR><TD CLASS="quote">I've heard that some aftermarket IMs dont have the secondaries like the stock GSR IM does anyone know if thats true? </TD></TR></TABLE>
Yes, that is true.
~Chuck
Yes, that is true.
~Chuck
for a GSR when u install a new IM u will need to tune the car. if u r using a stock GSR ecu, u will need to raise the VTEC to around 5K
i got a SKUNK2 PRO series IM with a SKUNK2 66mm TB on my LS/VTEC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 »</TD></TR><TR><TD CLASS="quote">for a GSR when u install a new IM u will need to tune the car. if u r using a stock GSR ecu, u will need to raise the VTEC to around 5K
i got a SKUNK2 PRO series IM with a SKUNK2 66mm TB on my LS/VTEC</TD></TR></TABLE>
Does the skunk2 PRo series IM have secondaries and stock sensors to be used and did that setup give u gains throughout the RPM range or just for top end power. Have you lost any power?
Superdragr45
10
Feb 12, 2004 05:09 AM
