Skunk2 tb on d16y7
Old 11-03-2017, 02:54 PM
Harris89's Avatar
Default Skunk2 tb on d16y7
New here just put a 70mm skunk2 tb on my d16y7 and car idles at 2000rpm iv tried everything only thing that works is unplugging the map sensor but it's undrivible that way I know that's oversized but they sent wrong one so i put it on anyways.. also found out wires to iacv are is there any way to delete that
Old 11-04-2017, 02:35 PM
adamhunsicker's Avatar
Default Re: Skunk2 tb on d16y7
Have you tried screwing the red screw on the top of the throttle body all the way in?
Old 11-04-2017, 10:19 PM
JRCivic1's Avatar
A large replacement throttle body has no provision for a 3-wire IACV as needed on a stock D16Y7 intake manifold... so this will not function properly. The good news is that you ABSOLUTELY DO NOT NEED this at all... it will only LOSE power in the midrange and gain no power up top. I suggest you return it and get your $$$ back.
IF you were to install a Y8 Intake manifold (or equivalent), you could convert to a 2-wire IACV... but there is no stock ECU that would run this combination, so you would need to convert to a tunable engine management solution... and even then, as I stated above, it will lose power in the midrange and likely gain nothing at or near redline.
Old 11-05-2017, 07:42 AM
Harris89's Avatar
I put old throttle body back on and it jumps from 1000rpms to 2000rpms with no throttle response
This is thr d16y7 from 88 crx si thats giving me all the problems
Old 11-05-2017, 08:14 PM
JRCivic1's Avatar
Your photo shows a Y7 longblock with a Z6 Intake manifold... sitting in the engine bay of a 4G Civic or CRX. Now that you have posted the make, model, year of the chassis, could you please post the ECU being used, the wiring changes that have been done, and a more specific list of engine mods instead of simply saying a "D16Y7".
Old 11-05-2017, 11:05 PM
Harris89's Avatar
I figured it out I got a new map and changed tps... I was just trying to put a slightly bigger throttle body on for a little more pep didn't know they were going to send me one that damn big
PR8urVtec
09-10-2015 05:45 PM
waynesumner
05-20-2013 06:55 PM
misterpsycho
04-14-2005 10:47 AM
asefi944
04-11-2005 09:43 PM
Quick Reply: Skunk2 tb on d16y7
