Clutch Issues..........................
Somethings up with this clutch of my gf car. !st it would grind gears and hesitate a lil espesially in 1st. So i replaced the slave. Drove it around for a week and then i couldnt get the thing in gear at all. The pedal feels fine. Any suggestions?
have you checked the MTF level? could it use a change maybe? also, when it's hard to select gears it could be the syncros, or even the clutch release bearing.
fellow PA member bump........
hth........
hth........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thelate1 »</TD></TR><TR><TD CLASS="quote">have you checked the MTF level? could it use a change maybe? also, when it's hard to select gears it could be the syncros, or even the clutch release bearing.
hth........
Thanks big!! Any other suggestions
hth........
</TD></TR></TABLE>Thanks big!! Any other suggestions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_sedan »</TD></TR><TR><TD CLASS="quote">its your shitty SOHC tranny
Nope it a 99 gsr
</TD></TR></TABLE>Nope it a 99 gsr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_sedan »</TD></TR><TR><TD CLASS="quote">then its your shitty DOHC tranny</TD></TR></TABLE>
Nope, it aint shitty. Its a honda. Bad guess.
VTEC-LUDE
Nov 9, 2006 08:45 AM
