Change the transmission fluid.
Old Mar 2, 2002 | 03:54 PM
hb_racer's Avatar
Default Change the transmission fluid.
What should I use to change my transmission fluid? Also where is the bolts to take off to do the change? OKay, now I will tell you what I have. I have a b16a sirII. Please help me. I believe it needs a change. Never changed it since I got it. I got it in September of 2001.
Peace
Old Mar 2, 2002 | 03:56 PM
DragII's Avatar
25 Year Member
Default Re: Change the transmission fluid. (hb_racer)
stick 3/8 ratchet into drain plug
drain fluid
install drain plug
undo fill bolt right above drain plug
fill till it runs out of fill hole.
reinstall fill bolt
Drive away with a smile
Old Mar 2, 2002 | 04:14 PM
hb_racer's Avatar
Default Re: Change the transmission fluid. (DragII)
Thanks for the reply, but
ummm...
i know this is dumb and stupid... but please help... where is the fill bolt. If someone has a pic... please show me... when i find that i guess i could find the drain plug. Also what kind of transmission fluid should I use?
Peace
Old Mar 2, 2002 | 04:54 PM
Bror Jace's Avatar
hb_racer, the fill (& check) bolt is located 10"-14" above the drain plug. Most Hondas are 17mm, I think.
You'll need a funnel with a piece of hose to fill it as you'll have to go in sideways.
Be sure to use the correct fluid ... something especially designed for synchromesh trannies. Most common choices are Red Line MTL, or MT-90 if it's really warm where you live. This is what I've used for 10+ years. Or you can use the Honda MTF available at the dealerships.
Don't just use motor oil. If you need to use it in an emergency, swap it out ASAP.
--- Bror Jace
Old Mar 2, 2002 | 06:20 PM
hb_racer's Avatar
Default Re: Change the transmission fluid. (Bror Jace)
thanks... Got it...
If I could get a pic of the bolt... it would be great..
Thanks all..
Peace
blouthan
Transmission & Drivetrain
Mar 6, 2009 05:01 PM
ludeR917
Nov 16, 2003 12:09 PM
wessieball
Jul 20, 2002 05:29 PM
tweekerz
May 9, 2002 11:22 AM
Y2KGreenGSR
Sep 28, 2001 12:11 PM
