vacuum gage reads 20 inches at idle, is this normal?
Old Sep 28, 2005 | 03:08 PM
mkinpwrat12g's's Avatar
Default vacuum gage reads 20 inches at idle, is this normal?
im running a d16y8, 16g, fmu, 310 cc injectors, fron mount and dsm blowoff valve. when i get into it the boost peaks at like 4 or 5 pounds of boost. it seems ok, but i ussually hear about turbos running at 8 pounds. the vacuum gage at idle is like 20 inches and when i step into it its like 0 than goes to boost and the boost peaks at like 4 or 5 pounds at like 7800 rpm. the car seems real quick and seems to be running good, just wondering if this is all normal, thanks honda-tech
Old Sep 28, 2005 | 03:18 PM
Forrest Gump 9's Avatar
Default Re: vacuum gage reads 20 inches at idle, is this normal? (blackpearlej8)
Yeah, it's normal. 20-10 in vacuum is normal.
Old Sep 28, 2005 | 03:21 PM
Rod.'s Avatar
Default Re: vacuum gage reads 20 inches at idle, is this normal? (Turbo9Nut)
that is what you want
Old Sep 28, 2005 | 03:53 PM
what about the boost peeking at 4 pounds
Old Sep 28, 2005 | 06:41 PM
nota-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackpearlej8 &raquo;</TD></TR><TR><TD CLASS="quote">what about the boost peeking at 4 pounds</TD></TR></TABLE>
You're only getting 4lbs out of a 16G? TD04 16G, correct?
I have a TD04 16G on my Z6 and I get to about 7-8psi at around 6k rpm.
Old Sep 29, 2005 | 02:30 PM
Default Re: vacuum gage reads 20 inches at idle, is this normal? (nota-eg)
yeah is the wastegate adjustible on it
Old Sep 29, 2005 | 02:33 PM
nota-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackpearlej8 &raquo;</TD></TR><TR><TD CLASS="quote">yeah is the wastegate adjustible on it</TD></TR></TABLE>
Not on mine. Mine is a DSM with an external wastegate. Something you may want to try is disconnecting the wastegate from the actuator. Just cap off the vacuum line you have feeding it and take it for a spin. See if it goes above 4psi.
The external wastegate for mine is all closed off funny, so if I opened it I wouldn't be able to put it back together correctly. In all honestly I just have mine disconnected from my turbo.
vtak2nr
Aug 27, 2009 03:59 AM
ash.zero
Jul 9, 2005 04:22 PM
krazn
Sep 16, 2004 10:12 AM
spike
Apr 28, 2004 08:39 PM
DXturbo
Jul 18, 2003 09:14 AM
