looks bad
Old Sep 28, 2005 | 02:34 PM
92civichatchsir's Avatar
Default looks bad
did a compression test
75 135 150 150
what does this mean
Old Sep 28, 2005 | 02:36 PM
hatchish's Avatar
which motor?
Old Sep 28, 2005 | 02:37 PM
Default Re: looks bad (92civichatchsir)
b18c1
also how many times am I suppose to let it crank
Old Sep 28, 2005 | 02:39 PM
JDM-EJ1's Avatar
Damn.
I would suggest a rebuild, or a new motor.
Old Sep 28, 2005 | 02:40 PM
hatchish's Avatar
your supposed 2 do it warm here look at this https://honda-tech.com/zerothread?id=1371511
Old Sep 28, 2005 | 02:42 PM
hatchish's Avatar
and read this http://www.motorage.com/motora...16170
Old Sep 28, 2005 | 02:44 PM
Earthworm Jim's Avatar
Default Re: looks bad (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">Damn.
new motor.</TD></TR></TABLE>
Old Sep 28, 2005 | 02:55 PM
Default Re: looks bad (Enigma_Performance1)
well went out there again and cranked it alittle bit more
90 180 180 185
then put a cap of oil in the first hole and got it to go to 120
so looks like Ill be doing a rebuild
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enigma_Performance1 &raquo;</TD></TR><TR><TD CLASS="quote">
New motor </TD></TR></TABLE>
A new motor would probably be easiest.. But building a new one would be fun.
Old Sep 28, 2005 | 02:58 PM
I am going to just build it to handle some more boost
Old Sep 28, 2005 | 03:08 PM
what piston and rods do you guys think I should get
Old Sep 28, 2005 | 03:10 PM
hatchish's Avatar
Listen here Ok kid i would suggest searching on h-t and other sites dont always trust peoples opinions make sure you dont half *** it build for your needs
Old Sep 28, 2005 | 03:12 PM
Default Re: (hatchish)
ok well I am wanting to make about 300 horse on about 10 psi...this is the only site I know of that would help out on this kinda stuff
Old Sep 28, 2005 | 03:13 PM
hatchish's Avatar
yeah use the search feature your best bet is copying someone else's set up remember search is your friend
Old Sep 28, 2005 | 03:14 PM
yeah thanks man
NOPIMAN
Apr 9, 2008 07:43 AM
CantKnckDaHustle
Mar 14, 2005 04:23 PM
fuck honda-tech
Aug 27, 2004 07:56 AM
AlphaQup
31
Jul 5, 2003 11:36 PM
