timing belt kit
Old Sep 28, 2005 | 12:20 PM
EF8IGHT's Avatar
Default timing belt kit
will a delsol vtec orcivic si b16 timing belt kit( tbelt water pump ect ) fit my jdm sirI motor?
Old Sep 28, 2005 | 01:22 PM
Suck my DX's Avatar
Default Re: timing belt kit (liviN L363ND)
yup
Old Sep 28, 2005 | 01:26 PM
MONSTERZC's Avatar
just remember to double check that the water pump has the same amount of teeth on it and you should be good to go
Old Sep 28, 2005 | 01:28 PM
Suck my DX's Avatar
Default Re: timing belt kit (MONSTERZC)
technically u should double check everything just to make sure that you get the right parts
Old Sep 28, 2005 | 02:08 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: timing belt kit (Suck my DX)
Check here for a list of known good part numbers:
https://honda-tech.com/zerothread?id=1024595
Makes it quick and easy if you are going to the dealerships...
Old Sep 29, 2005 | 01:06 PM
EF8IGHT's Avatar
i was accualy just going to order the prostreet one i have herd good things about it and it a lil cheaper
Old Sep 29, 2005 | 01:08 PM
Suck my DX's Avatar
Default Re: (liviN L363ND)
post a link so we can tell u if u should get it or not
Old Sep 29, 2005 | 01:43 PM
EF8IGHT's Avatar
Default Re: (Suck my DX)
http://www.prostreetonline.com...honda/
Old Sep 29, 2005 | 03:10 PM
Suck my DX's Avatar
its aftermarket.and just like anything else aftermarket, quality will be 50/50...u never know what ur gonna get until u run it...sometimes they will be better than oem ,sometimes they will be worse
i dunno when it comes down to replacing engine components i always go oem....but thats just me...if the motor is relatively stock it should be fine
Old Sep 29, 2005 | 04:55 PM
Crx Jimmy's Avatar
actually 99 civic and 95 del sol have different part #'s for waterpump or the tensioner i remember checking both when i had to do mine i used the 95delsol it was the same
Old Sep 30, 2005 | 09:43 AM
EF8IGHT's Avatar
ok well maybe ill got to a honda dealer
Old Sep 30, 2005 | 01:41 PM
ef8 h0!'s Avatar
OEM is the way to go. It may cost you a little more, but to have peace of mind on something that critical, it's a good idea.
EK9JSPEC
Aug 3, 2012 03:58 AM
PSU
18
Jan 30, 2010 09:38 AM
EJ8_Enthusiast
Oct 9, 2008 01:03 PM
t1g4
Oct 13, 2004 12:17 PM
SulphurDave
Feb 18, 2004 05:01 PM
