hatch won't open!
Old Sep 27, 2005 | 09:57 PM
roundworldsobig's Avatar
Default hatch won't open!
my hatch won't open. i have a 98 integra and i tried the switch under the hatch and it just won't budge open. and i cant get thru the back cause of the cover. what can i do?!
btw red springs that says sportline is from eibach right?
Old Sep 27, 2005 | 09:59 PM
Default Re: hatch won't open! (roundworldsobig)
OH and how do i remove the door panel, i took out 3 screws but it wont budge, any suggestions?
Old Sep 27, 2005 | 10:30 PM
verbol assassin's Avatar
fold the rear seats?
duh......
Old Sep 27, 2005 | 10:42 PM
toffytof's Avatar
try using the key and turning all the way (i can't remember which direction). if you turn it all the way and use the latch it should open. mine does this all the time. apparently there is some issue with the actuator or motor that is connected to the hatch latch.
Old Sep 27, 2005 | 10:47 PM
purehonda's Avatar
I swear I've responded to like 5 of these this month...For now just use the key(turn all the way to the right until it clicks, then pull the lever). go to acuraparts247.com for a breakdown of the parts...you'll need either the actuator or the whole motor assy. I just got used to using the key and unplugged the motor so it won't whine. Good luck
Old Sep 27, 2005 | 10:53 PM
there are no keyholes on the trunk
The_Ricky_Is
Oct 14, 2008 05:41 PM
brad98_teg
Sep 4, 2005 06:16 AM
53JDMDC2
Aug 7, 2005 03:38 PM
mkiv98
Dec 26, 2004 12:29 PM
