starting problems PLEASE HELP
Old Sep 27, 2005 | 09:13 PM
jsteplasy's Avatar
Default starting problems PLEASE HELP
ive got a serious problem with my car and i don't know what it could be..or where to start on fixing it. My car isn't starting anymore (like it doesn't give any fuel nor power to the engine--and for some reason--my radiator fan goes off!) i look at the cluster and i see all the lights are fine on standbye mode--but the engine light and the battery light are dimm. I changed the wiring harness from the motor to the ecu..changed the ecu..changed the ignition..checked fuses..bought new starter..and still no clue.
when i turn the ignition all the way it doesn't even choke--like theres no power at all. what could be the problem? or what can i do to get this fixed and get my street hatch back on the road? thanks
Old Sep 27, 2005 | 09:36 PM
hondakevin21's Avatar
Default Re: starting problems PLEASE HELP (jsteplasy)
Have you had the battery tested? And you did check ALL the fuses. What about you furl pump have you checked it out?
Old Sep 28, 2005 | 09:35 AM
jsteplasy's Avatar
Default Re: starting problems PLEASE HELP (hondakevin21)
yea..i checked the battery-it was dying out so i replaced it with a new one. i had all the fuses checked by my friend who was a mechanic and he said all the fuses were fine.
Old Sep 28, 2005 | 09:36 AM
jsteplasy's Avatar
the fuel pump's good because i replaced it with a friend's fuel pump..i took his walbro fuel pump because i went turbo.
is there anything else i should check?
Old Sep 28, 2005 | 01:47 PM
Suck my DX's Avatar
main relay could be ur problem
now when u try to start the car does it make a click when u turn the ignition or no sound at all? have u tested ur battery to see if it is still good? have u tried to jump start the car?: have u tried popping the clutch?
Old Sep 28, 2005 | 04:16 PM
redspiritguy's Avatar
Default Re: starting problems PLEASE HELP (Suck my DX)
check your battery cable terminals and wires for loose connections or corrosion. Also check the cable running to the starter.
Bloody Hatch
May 27, 2012 11:03 AM
edm_dc2
Apr 25, 2009 12:06 PM
stubk20
Oct 18, 2005 06:44 AM
koleah
Oct 2, 2005 02:33 PM
koleah
Sep 30, 2005 07:43 AM
