Hub Rings for Rota Slipstreams
Old Mar 2, 2002 | 11:03 AM
dwnthehatch's Avatar
Default Hub Rings for Rota Slipstreams
I finally got the time to mount my wheels. I realized they dont come with hub rings. Is that going to cause vibration or too much pressure on the lugs? Where can I find a set of hub rings? I went to NTB and they don't sell them. Thanks for your help!
Old Mar 2, 2002 | 11:18 AM
Frosty_spl's Avatar
Default Re: Hub Rings for Rota Slipstreams (dwnthehatch)
i noticed that too. Mine work fine. I dont think you need any.
Old Mar 2, 2002 | 11:40 AM
EVIL Lovebuzz's Avatar
New User
If you go to a place like Discount Tires or something, you should be able to buy them there.
Old Mar 2, 2002 | 11:57 AM
nwarp's Avatar
Default Re: Hub Rings for Rota Slipstreams (Lovebuzz13)
yep
Old Mar 2, 2002 | 01:18 PM
piscorpio's Avatar
uh, hate to sound dumb here, but what exactly are hub rings?
Old Mar 2, 2002 | 01:22 PM
Frosty_spl's Avatar
Default Re: Hub Rings for Rota Slipstreams (piscorpio)
are they nescessary?
Old Mar 2, 2002 | 03:58 PM
Hubcentric rings take the mounting pressure and centering force off the lugs and center it onto the hub. You're adding extra stress to the lug nuts by not running hub centric rings. It might seem like it fits "perfectly" but it's still not centered around that flange on the hub like OEM wheels are.
Old Mar 2, 2002 | 04:08 PM
piscorpio's Avatar
But what exactly are they? Is it placed under the lug, like a washer of some kind, or is it placed on the actual wheel hub, as the name suggests? Any website I could buy these from, I tried discount tire, but it doesnt show.
Old Mar 2, 2002 | 04:14 PM
deepnite's Avatar
of all the wheels ive had..only the rotas didnt need them...the rota s were made exclusively to fit honda market in asia...in only rare circumstances will anyone need hub rings if the rota s are mount d on honda or acura cars..
Old Mar 2, 2002 | 04:25 PM
Default Re: Hub Rings for Rota Slipstreams (deepnite)
When I had my enkeis they were little black plastic rings that filled the space between the hub and the hole in the center of the wheel.
Old Mar 2, 2002 | 11:37 PM
piscorpio's Avatar
ah, ok, I know exactly what you are talking about. Thank you for being patient with my ignorance!
Old Mar 3, 2002 | 12:13 AM
Troy's Avatar
you dont really need the rings with 15 and 16 inch wheels
Old Mar 3, 2002 | 04:58 PM
piscorpio's Avatar
Default Re: Hub Rings for Rota Slipstreams (Troy)
well if thats the case, Im all good!!
Old Mar 3, 2002 | 07:33 PM
tonyxcom's Avatar
Rotas are not made exclusively for hondas, but they are made to fit civic, integras etc with different hub sizes. If you have a non SI civic, your hubs will be smaller. My wheels wobbled a little bit with my stock civic cx brakes. I called MachIII about hubcentric rings and they told me Rotas are Lug-Centric. I dont belive that for a second. But I couldn't find a tire shop that would take the time to measure my wheels and hub to get me rings, they kept telling me that they dont have them or that I have to call rota for them. Blah!
However, after I upgraded to gsr brakes, my tires stopped wobbling. So maybe the hole on a 4 lug rim is just big enough for an integra so you can do without the rings.
Old Mar 3, 2002 | 10:45 PM
lucas569's Avatar
Default Re: Hub Rings for Rota Slipstreams (tonyxcom)
from what i gather konig makes the rotas or vice versa,in any case hubrings from konig wheel are what ive been told to use...
Old Mar 4, 2002 | 06:00 AM
Default Re: Hub Rings for Rota Slipstreams (lucas569)
I just ordered some at http://www.seriousauto.com for $17.16 shipped.
Old Mar 4, 2002 | 06:31 AM
june's Avatar
Well when i bought my slipstreams they came with plastic rings for the hubs. I guess it was just me??
Old Mar 4, 2002 | 06:47 AM
Default Re: Hub Rings for Rota Slipstreams (civicefhatchback)
All I got with mine were fake cf center caps.
Old Mar 4, 2002 | 08:23 AM
wakaru's Avatar
Now that just figures. I just recently bought my subzeros from them and they said all they had were rings for miatas, and didn't know if they'd fit my car. Right now I'm running them on my del Sol VTEC *without* rings, and have had the car up to an indicated 120mph with no apparent problems. When I mounted them, I hand-tightened each nut and turned the wheel through several revolutions while doing it. Once I had them finger-tight, I torqued them to the manual's specs. I'd still feel more comfortable having the rings though.
Old Mar 4, 2002 | 12:56 PM
piscorpio's Avatar
Default Re: Hub Rings for Rota Slipstreams (wakaru)
I have some slipstreams on the way, hopefully they have the rings in there, Im too paranoid of messing up my car to run without them now! I also hope having integra suspension parts in the rear will not effect the wheel fitment, which I doubt, but if anyone knows otherwise gimme a heads up.
Old Mar 4, 2002 | 05:13 PM
tonyxcom's Avatar
"I also hope having integra suspension parts in the rear will not effect the wheel fitment"
Absolutely not a problem.
Old Mar 4, 2002 | 05:14 PM
JSTOCK's Avatar
Okay....you people have me flipping out about this hub spacer issue. Is this really necessary?
Old Mar 4, 2002 | 07:46 PM
Default Re: Hub Rings for Rota Slipstreams (jstock107)
Every set of wheel I have bought came with the rings except my Rotas. I don't mind spending $18 for the peace of mind.
Old Mar 4, 2002 | 08:04 PM
piscorpio's Avatar
ditto...I just hope they conveniently come with the package.
Old Mar 4, 2002 | 08:43 PM
lucas569's Avatar
i dont think they come w/ the rims. most people have said they didnt get em unless you paid extra.
master honda tech
Apr 18, 2008 06:43 PM
Don Jefe
Sep 1, 2005 03:04 PM
NOSpeed97
47
Apr 6, 2004 06:28 AM
CROM
Oct 10, 2003 08:46 AM
darrinbrewer
Apr 7, 2003 08:10 PM
