prelude motor ?
Old Sep 27, 2005 | 05:32 PM
nayber's Avatar
Default prelude motor ?
im lookin at buying a 92 prelude the sticker in under the hood says it has 2.3 vtec anyone know good or bad, sorry new to honda im comeing over from the dsm world any info would be great thanks
Old Sep 27, 2005 | 05:37 PM
snowblind7x's Avatar
Default Re: prelude motor ? (nayber)
well if it's stock 2.3 vtec doesn't exist. It will either be a 2.3 non vtec or the 2.2 vtec.
Jordans95si's Avatar
they didn't make a 2.3 L vtec for preludes......what sticker are you talking about also....pics?????they made a 2.3 L vtec for accords....idk if you can swap them over to ludes tho
Old Sep 27, 2005 | 05:41 PM
Default Re: prelude motor ? (Jordans95si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordans95si &raquo;</TD></TR><TR><TD CLASS="quote">they didn't make a 2.3 L vtec for preludes......what sticker are you talking about also....pics?????they made a 2.3 L vtec for accords....idk if you can swap them over to ludes tho</TD></TR></TABLE>
you can swap them over. It's an H motor....Anyway, it's highly doubtful it's that engine.
Old Sep 27, 2005 | 06:11 PM
MLBZ521's Avatar
Default Re: prelude motor ? (snowblind7x)
Um.. If it's really a "Sticker" ( ) then I wouldn't trust it... Heh
What color is the Valve cover? What does the block say it is? H23A1, H22A1, H22A, H23A, F22A1... If it's a true Prelude motor then it should say one of the above.. Either USDM or JDM.. Otherwise if it is a swapped motor you would have to find out what is stampped on the block and then we could tell ya..
There are alot of combinations that could have it being an actual 2.3 VTec... Either a Euro Motor, Bored H22, or a H23 2.3L with a H22 2.2L Cly. Head..
So, to give a correct answer - more info is needed..
Old Sep 27, 2005 | 06:18 PM
nayber's Avatar
ill go back in the morning and get the code off it anyone know where they are stamped? it said 2.3 vtec on the cat sticker under the hood but reading thou the fourms i didnt belive that since everyone says there was not one so have more info in the morning thanks. if its the 2.3 non v is it still worth a damn i have a 300zx i was lookin at fixing up but like the lude better but with what id spend on it the 300 could be done
Modified by nayber at 7:50 PM 9/27/2005
Old Sep 28, 2005 | 05:45 PM
nayber's Avatar
ok its a h23a1 motor so 2.3 non v is it still a good motor? any info thanks
Old Sep 28, 2005 | 06:51 PM
PrecisionH23a's Avatar
FAQ
BeersieJr
Feb 28, 2014 06:39 AM
korney
Dec 11, 2005 11:35 AM
Fresno_NSX
Aug 29, 2005 06:24 PM
BDRphaseTWO
Aug 2, 2005 02:53 PM
93PGTZE
Aug 22, 2002 07:02 AM
