JDM B16A Idling at 2400 RPM?!?! How do I lower Idle speed???
Old Sep 27, 2005 | 04:26 PM
phoQ's Avatar
Default JDM B16A Idling at 2400 RPM?!?! How do I lower Idle speed???
I just bought a 1992 Integra GSR. The previous owner swapped in an SiR II B16A motor, and everything seems great the only thing that seems to be wrong with it is the super high idle(around 2400 rpm). When I switch the air conditioning onto MAX it drops to about 1500 rpm. WHat do I need to do to get it to idle right???
Old Sep 27, 2005 | 07:31 PM
Junkyard2000's Avatar
Default Re: JDM B16A Idling at 2400 RPM?!?! How do I lower Idle speed??? (phoQ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phoQ &raquo;</TD></TR><TR><TD CLASS="quote">I just bought a 1992 Integra GSR. The previous owner swapped in an SiR II B16A motor, and everything seems great the only thing that seems to be wrong with it is the super high idle(around 2400 rpm). When I switch the air conditioning onto MAX it drops to about 1500 rpm. WHat do I need to do to get it to idle right???</TD></TR></TABLE>
while idling, play with the idle screw
Old Sep 27, 2005 | 08:10 PM
phoQ's Avatar
Default Re: JDM B16A Idling at 2400 RPM?!?! How do I lower Idle speed??? (Junkyard2000)
what if that doesnt do anything? its turned all the way to the right, should I turn it to the left, i just didnt want to mess anything up.
Old Sep 27, 2005 | 08:16 PM
ur not gonnna mess anything up adjusting the idle. If that dont work u might have a leak somewhere or maybe a bad valve.
Old Sep 27, 2005 | 10:11 PM
Malgerus's Avatar
Shut the FITV.
https://honda-tech.com/zerothread?id=699787
Check for vacuum leaks.
Try resetting the idle.
Check throttle cable tension.
Old Sep 28, 2005 | 09:08 AM
phoQ's Avatar
it says that the FITV is only on obd 0 motors, i have sir II B16A. should I have one. ima go look anyways.
Old Sep 28, 2005 | 10:41 AM
g-ride-si's Avatar
my eacv actually made my motor run like that.
Old Sep 28, 2005 | 12:27 PM
phoQ's Avatar
Default Re: (g-ride-si)
whats eavc???
Old Sep 28, 2005 | 04:14 PM
g-ride-si's Avatar
electronic air control valve, or iacv (intake air control valve. its on the back of the intake mani. just pull it off and spay inside it with carb cleaner/starter fluid let it dry and put it back in. Even if it dont work it wont hurt.
Old Sep 28, 2005 | 05:32 PM
phoQ's Avatar
okay will do, thanks
Old Sep 28, 2005 | 11:29 PM
Malgerus's Avatar
Default Re: (phoQ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phoQ &raquo;</TD></TR><TR><TD CLASS="quote">it says that the FITV is only on obd 0 motors, i have sir II B16A. should I have one. ima go look anyways.</TD></TR></TABLE>
Yes, I believe you'll have one on but it will be mounted in your throttle body. I could be wrong.
Old Sep 29, 2005 | 01:38 AM
bs-inc's Avatar
Default Re: (Mr. S)
Sometimes mine idles at 1100 when I start it. Then when I drive it around for a couple minutes, it idles around 2000.
Old Sep 29, 2005 | 11:23 AM
phoQ's Avatar
lol i fixed it...
it was just the throttle cable.
at first i thought the tb might just be sticking but it was just the cable needed to be adjusted.
Old Sep 29, 2005 | 01:14 PM
Malgerus's Avatar
Default Re: (phoQ)
Nice!
usually it's the simple things...
Old Sep 29, 2005 | 05:27 PM
phoQ's Avatar
yea I feel so much better now. I've just had so much car **** to deal with lately that I get super paranoid about small ****.
Vtak_GoKart
Aug 25, 2015 06:27 AM
JustEFit
Jul 22, 2013 06:43 AM
BlkB16aEJ
Aug 3, 2007 10:53 PM
95hyrbidex
May 8, 2003 08:32 PM
