B16a Bad Idle
Old 08-03-2007, 04:52 PM
BlkB16aEJ's Avatar
Default B16a Bad Idle
hi everyone my problem is when i turn on my car only in the morning or when the motor is cold and hasnt been on for a while the car will idle at about 100 rm. almost about to turn off but doesnt then it revs up by itself to 1300 rpm then back down to about 200 if i try to give it gas it sputters but never turns off after about 3 times that it doses that its warms up that way but not going down to 200 rpm it reves up and down from 1000rpm to 1800rpm till its warm n steadily idles at about 1000 rpm. this only happens when its cold any help is appreciated thank
Old 08-03-2007, 10:45 PM
MISHN's Avatar
Default Re: B16a Bad Idle (BlkB16aEG)
check your IAVC (idle air control valve) those tend to go bad once in a while.
Old 08-03-2007, 10:47 PM
hmtcrxsir's Avatar
Default Re: B16a Bad Idle (AFRO GUY)
yeah try cleaning the IAVC with brake cleaners. it works sometimes
or sometimes if your water level is low in your radiator the idle tends to do that as well
Old 08-03-2007, 10:53 PM
MISHN's Avatar
Default Re: B16a Bad Idle (hmtcrxsir)
brake or carb cleaner. same thing
JustEFit
07-22-2013 06:43 AM
225DC2GSR
06-22-2005 10:42 AM
EGkid
06-01-2005 12:03 PM
LD_EGSICK
01-21-2004 05:42 PM
doh boy
08-19-2003 09:34 AM
Quick Reply: B16a Bad Idle
