92 accord f22a ignition problems
Old Sep 27, 2005 | 12:56 PM
samion33s's Avatar
Default 92 accord f22a ignition problems
ok about three days ago i noticed my car started to idle funny sometimes and run kind of shitty well i get to my garage and start checking **** and i find my coil wire came out of the connector and was jammed into the dist. plug so i said how the hell must of been one of my friends when they were helping me work on it so i went up and bought the accel 8mm sparkplug wires and i had new spark plugs anyways so went ahead did a tuneup then i found my coil itself was cooked at the part where the coil wire plugs into it! so i went go an msd blaster coil tested my 3 wires tach power ground hooked it up and started sounds like it runs good! well today im driving barelly on the throttle and i notice it falling on its face then i goose it and it picks up no detonation just bogged down real bad!! so what do you think it is? i was maybe thinking the coil is not getting a strong enough signal maybe i should upgrade my ign with an msd box... anyone run into this kind of thing!
Old Sep 27, 2005 | 03:47 PM
gianinline's Avatar
..you said you did things with your friends and stuff... well... no one cares more about your car than you right?!... so... if you really can't figure out the problem.... see if find a mechanic that gives an idea of what it is... and actually, no only one... but a few... 3 opinions at least..... ...if 2 mechanics point to one thing... ...fix it!
Old Sep 27, 2005 | 03:58 PM
samion33s's Avatar
Default Re: 92 accord f22a ignition problems (samion33s)
yeah every mechanic will say something on the lines of its your turbo or its electrical i let my friends do little things so that i dont have to **** with that **** while im under my car or messing with other stuff maybe this has also taught me a lesson to double check everything!! friends or no friends! still dont know what the hell it is its like im hitting fuel cut sometimes but i know im not!
philafelman
Aug 1, 2009 07:07 PM
Cpt Ben
Apr 18, 2006 10:21 PM
rice_classic
Jul 15, 2005 09:49 PM
Steve Berman
Aug 22, 2002 04:52 PM
BoroDB8
Apr 18, 2002 03:26 PM
