Honda S2000 Honda S2000
Help !!!! 17x8 17x9
Old Sep 27, 2005 | 11:26 AM
s2khic's Avatar
Default Help !!!! 17x8 17x9
Does anyone know if a 17 x8 +47 and 17 x9 +47 wil fit an s2000
Old Sep 27, 2005 | 11:32 AM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: Help !!!! 17x8 17x9 (s2khic)
What kind of wheels?
The offsets seem close enough, but the people I know with 17x9 rears run a +50 offset. 3mm should matter much though. Seems like you're about 5mm over on the front offset.
Old Sep 27, 2005 | 11:55 AM
s2khic's Avatar
Default Re: Help !!!! 17x8 17x9 (Sideways2000)
Work rezax's
Old Sep 27, 2005 | 12:00 PM
s2khic's Avatar
So do you think that they will fit ??? dont know if i should risk it ....
Old Sep 27, 2005 | 12:10 PM
cmdr430's Avatar
what size rear tire?
are you lowered?
i ran 47 8" r offset emotions w/ 245x40 17 rear w/ no probs lowered 1"
when i ran 255x40 rear there was a slight rub on large dips....
Old Sep 27, 2005 | 12:38 PM
s2khic's Avatar
Default Re: Help !!!! 17x8 17x9 (cmdr430)
I havent bought them yet....... still deciding...... im worried they wont fit right !
Old Sep 27, 2005 | 12:45 PM
s2khic's Avatar
Think that there 235 45 17
Old Sep 27, 2005 | 12:51 PM
papa5murf's Avatar
rears will stick out..... they'll also rub if you're dropped...
Old Sep 28, 2005 | 10:40 AM
mugenstwok's Avatar
Default Re: Help !!!! 17x8 17x9 (03s2kblue)
wrong, it'll fit up to 245/45/17 for rear and don't give false information.
Old Sep 28, 2005 | 10:43 AM
* B A N N E D *
Default Re: Help !!!! 17x8 17x9 (mugenstwok)
I guess that makes you wrong, because you're supposed to run 40 series rear.
Old Sep 28, 2005 | 01:17 PM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenstwok &raquo;</TD></TR><TR><TD CLASS="quote">wrong, it'll fit up to 245/45/17 for rear and don't give false information.</TD></TR></TABLE>
how bout you not give out false info......
rears will be 40.. fronts are 45...
you might want to know what you're talking about (facts) before you start bashing/bitching...
9inch rear with a 47 offset with the (PROPER TIRES) will stick out...
the point of having a 9inch rear wheel is to run 265's+... it's pointless to get a wide wheel (more weight) and then put a small little dinky tire on it...
Old Sep 28, 2005 | 01:19 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue &raquo;</TD></TR><TR><TD CLASS="quote">
the point of having a 9inch rear wheel is to run 265's+... it's pointless to get a wide wheel (more weight) and then put a small little dinky tire on it...</TD></TR></TABLE>
"Proper tires? I have to worry about proper tires?"
mugenstwok : Yea like.. there are these things called "wheel speed sensors", and this crazy *** **** called "ABS" , and if you **** up something lame like rolling diameters, your "Awesome Braking System" doesnt work right and it throws off your F/R brake balance. But "wut da fawk" do I know, I don't even own an S2000, let alone drive one hard enough to notice.
Excuse the sarcasm. Seriously man, do some reading.
Old Sep 29, 2005 | 10:26 AM
s2khic's Avatar
okay okay okay..... well to let everyone know.... i tried them on and yes they DID NOT FIT ! the wheels stood out like 1/2 inch. Thanks for all the input guys... it was worth the shot !
Old Sep 29, 2005 | 10:59 AM
* B A N N E D *
It stuck out 1/2" at all 4 corners?
Old Sep 29, 2005 | 01:47 PM
papa5murf's Avatar
well looks like mugenstwok has nothing to say.... lol... (dumbass)
* you should make a note to yourself... next time don't call someone out (especially when they are right)... when you yourself don't know the facts*
Old Sep 29, 2005 | 01:53 PM
WowOzYouRock's Avatar
maybe mugenstwok thought that hmmm it has 5 lugs so it should fit LMAO
Old Sep 29, 2005 | 01:54 PM
papa5murf's Avatar
Default Re: Help !!!! 17x8 17x9 (Y2K_S2K)
lol
dartonh22
Honda S2000
24
Jun 11, 2008 06:21 AM
HeavyFoot_Tony
Honda S2000
Dec 3, 2005 07:38 PM
GEN2TEG
Honda S2000
Sep 5, 2005 12:57 AM
sebmour jdm
Honda S2000
11
May 27, 2005 02:27 PM
quick108
Honda S2000
10
Mar 7, 2003 05:50 PM
