Weird - 1 yr long problem - no conclusion - P13, p14? WTF
Old Sep 27, 2005 | 10:24 AM
The Weather Man's Avatar
Default Weird - 1 yr long problem - no conclusion - P13, p14? WTF
Ok.........
I've been running my car on a p14 ecu for a while.......
why?
Because the car runs horribly!(not driveable) on the p13 ecu.....
WTF!
hmm.......
I know the p14 is tuned for i think 240cc? injectors.........i have 345cc injectors on my car.........
the only way i can get the car to be driveable is to up the fuel with my VAFCII - I'm talking like 10%+........just to make it driveable.........on p13
The p14 - I don't have to do ****........it drives very well.......a little rich though
Is the timing a huge difference on the h22 and h23 motors?.......
need to get this fixed ASAP! If i can't fix it soon, I'm just going to get an s300 and tune it to drive well...........
So far, I only have UD Pulley, I/H/E........
I wonder if something went wrong during the swap.....hmm..........
Forgot to mention that I plugged it up to a P28 ecu - and it did the same thing........Those don't have 345cc injectors do they? - pretty sure they don't.
Old Sep 27, 2005 | 11:31 AM
IHateJDM's Avatar
Default Re: Weird - 1 yr long problem - no conclusion - P13, p14? WTF (TheKingPin)
it sounds like something is wrong with that p13.
Old Sep 27, 2005 | 11:34 AM
md23vtec's Avatar
Default Re: Weird - 1 yr long problem - no conclusion - P13, p14? WTF (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like something is wrong with that p13. </TD></TR></TABLE>
I was thinkg the exact same thing
Old Sep 27, 2005 | 07:58 PM
Well - i plugged in a p28(?) - some civic ecu w/vtec and it did the same thing.........
I'm going to change my O2 sensor here pretty soon - what is a good O2 sensor? I heard not to use Bosch - for some reason - thats too bad actually because here at school, we get discounts on parts(NAPA).....and the only o2 sensors Napa sells are bosch.........that sucks.......
Old Sep 27, 2005 | 08:01 PM
Eddiebx's Avatar
whats wrong with a bosch sensor, they work like any other sensor, if u can getit for cheap go for it
Old Sep 27, 2005 | 09:14 PM
PrettyLude's Avatar
bosch user here, works fine now for a year, the price difference is a big difference, you can get good prices at oxygensensors.com
Old Sep 27, 2005 | 09:15 PM
PrettyLude's Avatar
p14 is designed to run with the 345cc injectors
Old Sep 28, 2005 | 04:15 AM
Oh really? So the h23 has the same fuel injectors eh.....hm........so what the hell could be the problem.
Is one ECU more dependent on the closed/open loop operations than the other?
Old Sep 28, 2005 | 05:00 AM
flyrod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKingPin &raquo;</TD></TR><TR><TD CLASS="quote">i have 345cc injectors on my car.........</TD></TR></TABLE>
Are you sure? What is your fuel pressure?
Old Sep 28, 2005 | 05:16 AM
pentaq's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">p14 is designed to run with the 345cc injectors</TD></TR></TABLE>
don't think so.
are you sure you have 345s?
Old Sep 28, 2005 | 05:23 AM
Default Re: (Stuartz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stuartz &raquo;</TD></TR><TR><TD CLASS="quote">may itz tha stupid driver ayeeeeeeeeeeeez </TD></TR></TABLE>
WTF? Man i'm reporting this post....don't come in here talking crap - this is your first post..........
I'm pretty sure my car has the 345cc injectors - I'll try to check my fuel pressure later on in the day.......
what is the p14 tuned for then?
The car runs like total **** - unless i sit there and keep trying to rev it.......then after a long while, it becoms driveable......but stalls and has no power.......
Old Sep 28, 2005 | 09:54 AM
Altilude's Avatar
are you sure you have the injectors from a h22a?, you say they are the 345's - but is it possible whoever did the swap - swapped them out for the h23's? visibily there is very little/no difference between the h23's injectors and h22a's - and they would surely cause your bogging issues. or i don't believe you mentioned what engine you actuall swapped in was it a jdm h22a? or is it a h22a4? because i believe there would be a difference between saturated and peak and hold injectors.
if you aren't sure, and don't want to buy more, you could always get them flow checked somewhere.
Old Sep 28, 2005 | 10:20 AM
OH.......
I'm always willig to buy more just in case. I actually had an extra set - but i just sold them to DarkBB4.........
If anyone has any - just let me know. I have payapl.
Its a JDM h22a by the way.
What size injectors does the p28 use?
Old Sep 28, 2005 | 10:22 AM
IHateJDM's Avatar
Default Re: (TheKingPin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKingPin &raquo;</TD></TR><TR><TD CLASS="quote">OH.......
What size injectors does the p28 use?</TD></TR></TABLE>
240 cc i think. not 100% on that.
gceniceros209
Feb 7, 2011 02:01 PM
gceniceros209
Jan 16, 2011 01:28 PM
PremiumPrelude
Mar 12, 2008 01:25 PM
preludefien
Jan 16, 2007 10:45 AM
Kwaakku
Nov 3, 2005 06:48 PM
