ac removal
ok, got a drag third gen for my dc gsr teg, every thing was going well until i found that the intercooler piping was not going anywhere until i removed the windsheld washer fluid resivoir and also the ac compressor was in the way. my cuz had to bend the ac fan to pop out and poked a hole in the radiator by accident. (bitchass wreckless fool) i'm afraid this will leak under pressure, anyways, how can i drain the fluid out of the ac compressor and what needs to be removed. anyone with the same problem? resolution? suggestions??
what i did was use a hose that fits around the little a/c thing then route the other end of the hose into a empty container, like an empty gallon of gallon, but leave a little water inside of it,drain it slow, don't open it all the way
Modified by Sar Face at 11:10 AM 12/11/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bottomzup »</TD></TR><TR><TD CLASS="quote">not sure of specifics, but dont just drain the freon. It's SUPER illegal cause of enviromental stuff. take to local shop.</TD></TR></TABLE>
yea theyll gladly take free freon from you. I was stupid 3 years ago and vented it from my garage. I was scared shitless because I had the garage and side door wide open and the mailman and garbage came by. The air in my garage was like yellowish and kept venting for more than 20 mins
throw a towel over the holes and then with a long screwdriver push the pin to the side to drain the freon then pull it all out. thats what i did for my sohc turbo install
pliskin679
Aug 11, 2010 01:25 AM
john666
Sep 7, 2004 11:18 PM
