_-_-_-_Tranny making a funny chatter sound, but only in 1st??? Any clues?_-_-_-_
Old Sep 26, 2005 | 07:59 PM
Touch's Avatar
Default _-_-_-_Tranny making a funny chatter sound, but only in 1st??? Any clues?_-_-_-_
When I put the gear in first, I get this metal on metal vibrating soung, and if I tap down on the shifter, makes a noise as well, but only in first. all the other gears are smooth and make no noise. Is it clutch chatter? Is it a bearing problem? Is the gear grinding? Please need help.
Old Sep 26, 2005 | 08:59 PM
Touch's Avatar
Default Re: _-_-_-_Tranny making a funny chatter sound, but only in 1st??? Any clues?_-_-_-_ (Touch)
bump for help
Old Sep 27, 2005 | 03:49 AM
Touch's Avatar
help
Old Sep 27, 2005 | 10:28 AM
Muckman's Avatar
Moderator in Chief
Sounds like clutch chatter. Do you have an aftermarket clutch?
Old Sep 27, 2005 | 09:08 PM
Touch's Avatar
Default Re: _-_-_-_Tranny making a funny chatter sound, but only in 1st??? Any clues?_-_-_-_ (Muckman)
no, it's a stock clutch. I just swapped in the motor. I didn't hear it or feel it in the car we pulled the motor out of
Old Sep 28, 2005 | 07:52 AM
blueeg's Avatar
how about the flywheel? did you change it when you did your swap or is it the same one from before
Old Sep 29, 2005 | 04:48 PM
Touch's Avatar
Default Re: _-_-_-_Tranny making a funny chatter sound, but only in 1st??? Any clues?_-_-_-_ (blueeg)
The flywheel is the same. If it was something like the clutch or flywheel, wouldn't it affect all the gears, and not just first. If I just let the car roll in first without giving it gas, it squeaks.
Old Sep 29, 2005 | 07:55 PM
Horseman's Avatar
it could be your first gears, like some of the teeth arent they or wearing down, or it could be the clutch cables??
Old Sep 29, 2005 | 09:48 PM
BB6racer's Avatar
either your 1st gear, or a bearing. i had this problem with 4th gear, and a tranny shop said it was a 4th gear bearing. they replaced it and now the noise is gone. does your tranny have a hard time shifting into/out of 1st?
Old Sep 29, 2005 | 10:19 PM
Touch's Avatar
Default Re: (BB6racer)
I wouldn't say I have a hard time going into first, but it's a little stiffer than the other gears, and when I put it into first it squeaks.
Old Sep 30, 2005 | 04:41 AM
Touch's Avatar
help.
eg_b18c
Transmission & Drivetrain
17
Oct 31, 2018 07:24 PM
jbpnoman
Feb 25, 2012 03:45 PM
suje
Oct 27, 2011 02:28 PM
NonovUrbizniz
21
May 2, 2005 05:39 PM
d_mina
Feb 3, 2005 12:06 PM
