Cluster problem...
Old Sep 26, 2005 | 04:01 PM
American.Graffiti's Avatar
Default Cluster problem...
I have a 94 Civic CX with a EX cluster and here's my situation. I was driving the other day w/ my gf and she pointed out that my cluster wasnt working. I mean not even my turn signals. The only thing that comes on is the battery light. I went home and checked my fuses and all of them are good, I thought it was my cluster so I switched it with my spare CX one and it was still doing the same thing. I cannot figure out what it is. Any help would be great.
Thanks in advance,
-Jeff.
Old Sep 26, 2005 | 05:37 PM
sbcs15's Avatar
Default Re: Cluster problem... (Falkien)
Sounds like you have a CLUSTER ,that's Clustered
Sorry I couldn't resist.
I would sand the copper terminals in the plug if they look tarnished at all, some times they get corroded and don't make conact
Old Sep 26, 2005 | 05:40 PM
Sliced Beard's Avatar
Default Re: Cluster problem... (sbcs15)
did you recently remove your guage trim?
if you install the clock plug in teh hazard switch then it will cause all sorts of problems.
Old Sep 27, 2005 | 09:53 AM
Default Re: Cluster problem... (DirtySol)
1. I cleaned all of the connections.
2. I know what your talking about and I fixed that, I rode for months before this happend. The only thing that was wrong with my cluster was that its lights wouldnt come on. So Im probably gonna go over everything again.
Thanks for the help and Ill let you all know if I fixed it,
-Jeff.
Old Sep 27, 2005 | 03:46 PM
Bump.
Old Sep 27, 2005 | 04:05 PM
germz's Avatar
i have the exact same problem...i found out a temporally. solution. Just open your steering column cover and behind your ignition you'll see wires. Tap the one that says BAT (very small writing) to your gauge cluster on back (any connection with a + terminal)
everything should work. i just can't find out the problem.
hope that helps
Old Nov 1, 2005 | 08:18 PM
teg969's Avatar
Default Re: Cluster problem... (germz)
bump having the same problem on my 93 hatch...noithing is working except batterie light..please help!!
nihad
Mar 30, 2008 09:41 AM
I4
Oct 6, 2007 01:20 PM
kcrxxx
Jul 27, 2007 01:42 PM
American.Graffiti
11
Jul 4, 2006 04:25 PM
ronintegra
Jan 3, 2006 12:10 PM
