anyone make a home made camber kit for the 90-97?
Old Sep 26, 2005 | 01:43 PM
efficiencyJunkie's Avatar
Default anyone make a home made camber kit for the 90-97? (Alignment specs added!)
I installed a eibach prokit on my car, but the specs are way off. it wants to track the the right now, I will update the post with the specs the alighment shop gave me up here. (the caster is actually off)
anyone do any mods for something like this? (since its onlye a 1.1 inch drop, im thinking a camber kit is overkill)
Modified by carbnjunkie at 11:23 PM 9/26/2005
Old Sep 26, 2005 | 07:42 PM
gianinline's Avatar
Default Re: anyone make a home made camber kit for the 90-97? (carbnjunkie)
dawg.... I got some rear arms for the lowerded rear wheels... let me know if you need them.... I'll make sure I get a good price for you
Old Sep 26, 2005 | 10:22 PM
Default Re: anyone make a home made camber kit for the 90-97? (gianinline)
Thanks for the offer, let me first figure out if it will help this problem. (ill keep your sn!)
Old Sep 27, 2005 | 05:17 AM
aZnAcCoRd02's Avatar
save yourself a penny and look up "rear washer trick" when i got my alignment done they used it in the rear for mine
Old Sep 27, 2005 | 08:29 AM
Starrman85's Avatar
Default Re: anyone make a home made camber kit for the 90-97? (aZnAcCoRd02)
i lowered my car, got a camber kit installed for the front of my car, and then got an alignment. didn't even do the washer trick for my rear wheels, and I've never had a problem with uneven tire wear in the back.
and with the camber kit, the front is fine. I have an Ingalls camber kit. Lowered on H&R sport springs, which i think is about a 1.2" drop? anyways, i don't think a camber kit is overkill, i think it's a necessity for anything lower then stock.
Old Sep 27, 2005 | 09:07 AM
96Sedan's Avatar
Default Re: anyone make a home made camber kit for the 90-97? (STARRMAN85)
I took my car to Miami chasis and they cambered it using washers to flare out the wishbone so you could try that. It does a pretty good job...cheap and saves me money cause it doesn't cut the tires.
Old Sep 27, 2005 | 09:16 AM
jb.'s Avatar
jb.
https://honda-tech.com/zerothread?id=1257911
thats a write up i did on my 5th gen
Old Sep 27, 2005 | 09:48 AM
Default Re: anyone make a home made camber kit for the 90-97? (jbkiksass69)
how about the caster that is of in the front wheels? Everything was in spec when it was stock.
Modified by carbnjunkie at 10:59 AM 9/27/2005
Old Sep 27, 2005 | 12:32 PM
swisher_man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbkiksass69 &raquo;</TD></TR><TR><TD CLASS="quote"> https://honda-tech.com/zerothread?id=1257911
thats a write up i did on my 5th gen</TD></TR></TABLE>
I needed that too...thanks. btw, happy 1 yr anniversary with honda-tech.... yeah i noticed that but my girl is bitchin bout ours.... talk about puttin cars first haha
Old Sep 29, 2005 | 03:36 PM
stillrockin18s's Avatar
Default Re: anyone make a home made camber kit for the 90-97? (swisher_man)
carbnjunkie - I would get a camber kit for your car, its pretty much a must when you lower it or your gonna get werid tire wear.
Old Sep 29, 2005 | 10:10 PM
Default Re: anyone make a home made camber kit for the 90-97? (lowriden_acura)
yah i agree, problem is, its not going to effect that damn caster! ark...this is going to hurt the handling too, the opposite of what most springs do!
Stupid_Hurts
Honda CR-V & Element
25
Oct 13, 2011 08:20 PM
dixie Normas7
Sep 8, 2006 11:17 AM
Shingo
10
Jun 30, 2005 11:40 AM
