gsr pistons in a b18a1 will it work?
Old Sep 25, 2005 | 10:22 PM
integra boy's Avatar
Default gsr pistons in a b18a1 will it work?
was wondering if this would work are they the same bore size and pin hieght?
Old Sep 25, 2005 | 10:24 PM
Lauj87's Avatar
pretty sure it will work..all be series parts are almost interchangable.
Old Sep 25, 2005 | 10:27 PM
Default Re: (Lauj87)
do you think it would be a good power gain as far as compression ratio with the ls head thanks for your reply
Old Sep 25, 2005 | 10:30 PM
Lauj87's Avatar
depends if your looking for all motor or boost. if boost i'd say stick with your stock pistons....NA go GSR..would raise your compression but im not sure by how much. as far as HP gains im sure you would get some what of a gain with GSR pistons but not much.
Old Sep 25, 2005 | 10:32 PM
Kendall's Avatar
Consider PR3 pistons from a first gen B16 or any US market B16. They'll give you somewhere in the neighborhood of about 11:1 compression.
Old Sep 25, 2005 | 10:33 PM
projectTeG's Avatar
yea they will work the rings are the same, but i believe youll have to do the same thing to get the pistons on the ls rods like you would to the ITR pistons.....mill the small end of the rod.
Old Sep 25, 2005 | 10:36 PM
Default Re: (Kendall)
thanks for all the help also i have a jdm gsr intake will this work with a few mods? oh yeah and what im wanting to do is build a Ls sleeper looks like an LS but its not
Kendall's Avatar
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">yea they will work the rings are the same, but i believe youll have to do the same thing to get the pistons on the ls rods like you would to the ITR pistons.....mill the small end of the rod. </TD></TR></TABLE>
That's only necessary for ITR or CTR pistons. GSR/B16/B17 pistons don't require this.
Old Sep 25, 2005 | 10:49 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">
That's only necessary for ITR or CTR pistons. GSR/B16/B17 pistons don't require this.</TD></TR></TABLE>
i thought the b18c1 pistons were like the ITR's....hrm sry bout that.
Old Sep 28, 2005 | 07:01 PM
popuppiston's Avatar
GSR, ITR you have to mill the rod or have the inside of the pistons shaved to clear the rod ends, B16, B17, Ls pistons fit without modifications. I know this because I just went thru this on my LS/Vtec.
Old Sep 28, 2005 | 07:02 PM
projectTeG's Avatar
Default Re: (popuppiston)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by popuppiston &raquo;</TD></TR><TR><TD CLASS="quote">GSR, ITR you have to mill the rod or have the inside of the pistons shaved to clear the rod ends, B16, B17, Ls pistons fit without modifications. I know this because I just went thru this on my LS/Vtec.
^ though i might have had that right.
Old Sep 28, 2005 | 07:18 PM
DC2SIR-G's Avatar
* B A N N E D *
y would u want gsr pistons in a LS??? get b16 pistons or ctr.
blackeg
Jul 15, 2014 03:01 PM
jhammond_82
Jul 14, 2009 10:09 PM
tealsvteceg
Feb 14, 2008 06:03 PM
recon23
Nov 6, 2007 04:50 AM
blundar
Apr 26, 2006 09:46 PM
