vtec and v-afc problems please help!!
Old Sep 25, 2005 | 08:32 PM
accordparts96's Avatar
Default vtec and v-afc problems please help!!
When i set my vafc at anywere below 5600 it dont work good the vafc screen says vto is on but it dont kick? no power it seems like loss of power. please help.
Old Sep 25, 2005 | 09:28 PM
F23Coupe's Avatar
Default Re: vtec and v-afc problems please help!! (accordparts96)
Check the VTEC solenoid filter to see if there is some cloggage there and check your oil level. VTEC won't engage without adequate manifold pressure and/or oil pressure.
Old Sep 25, 2005 | 09:31 PM
dtran002's Avatar
not enough fuel or somethin like that, i had the same problem wen i first got it, recommend change ecu or get it tuned
Old Sep 25, 2005 | 09:36 PM
95ACM's Avatar
Default Re: vtec and v-afc problems please help!! (F23Coupe)
Heres some quick info, if you have this on the Accord EX engine (f22b1) you won't feel anything ever, plus the v-afc isn't supposed to be supported for that engine. Anyways vtec on the SOHC motor should only engage around 2-3k rpms, which is optimal and for saving gas and *cough* power. Now if you did an h22 swap that's a different story.
Old Sep 25, 2005 | 09:50 PM
Default Re: vtec and v-afc problems please help!! (95ACM)
its on an h22 i have enough fuel .. what is the correction thing with the high and low cam for the v-afc.? adjusting this would help? or not there both set at o% hi and lo 0%
accordparts96
Sep 26, 2005 07:08 AM
B-HuTcHiE
Nov 24, 2004 07:46 AM
PreludePhill
Apr 4, 2004 10:50 AM
98R-1144
Nov 4, 2002 05:12 PM
EleanoR
Apr 17, 2002 06:06 PM
