battery/wiring/car not starting questions
Guest
Posts: n/a
1990 crx hf b16a, been running fine for 2 years. my question is, recently, when i get in my car to turn it on, as soon as i turn the key to acc or on, the battery dies. if i give it a few minutes, the battery sends voltage back out, and works fine, until i try to turn the key back on. itll do this a few times then eventually work good and start. what the hell is wrong?
i feel like i've said this alot this summer... probally cause the hot temp... its possible due to a bad main relay.. give more detail? check engine light? dies while driving? can you hear fuel pump prime?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghost_ryder35 »</TD></TR><TR><TD CLASS="quote">i feel like i've said this alot this summer... probally cause the hot temp... its possible due to a bad main relay.. give more detail? check engine light? dies while driving? can you hear fuel pump prime?
</TD></TR></TABLE>well, i guess my 3rd post wasnt very clear, since i move the battery around and it fires right up, im assuming im a dumbass and some battery cable is loose. I know its not the main relay, because i know what that does, and i fixed it. thanks for the help though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFB16ACRX »</TD></TR><TR><TD CLASS="quote">nobody loves me and since whenever i move the battery around, i should probably check the cables first, even though theyre ziptied down pretty good.</TD></TR></TABLE>
yea i dont think that was clear just stating you move the battery around
tooljst8
Mar 23, 2008 12:39 PM
MooreBoost
Aug 31, 2005 08:53 PM
