driver side window won't go up
Old Sep 25, 2005 | 08:57 AM
accordredliner's Avatar
* B A N N E D *
Default driver side window won't go up
The switch is messed up. The tested with an ohm meter and confirmed it.
Does anyone know how to fix it? I saw a couple of master switches on ebay with the same problem so I thought there might be a way to fix it since it is a common problem.
Old Sep 25, 2005 | 09:39 AM
jmd471's Avatar
Default Re: driver side window won't go up (accordredliner)
Take the switch apart and see what the problem is...only thing I can think of, could be as simple as just dirty contacts or broken connection. Nothing a soldering iron can't fix probably.
Old Sep 25, 2005 | 12:57 PM
* B A N N E D *
I took the switch out once and I don't you can dissemble it. Can somebody confirm this? Maybe I missed something
Old Sep 25, 2005 | 02:34 PM
ice_nine_h95's Avatar
if u need to move the window up, use a 12 volt battery or the
car battery and switch the polarity so that positve goes up and
negitive goes down. This should help you get your window up ( shortterm solution).
I had the same problem and swapped out the passenger switch and the master switch.
EndlEEsss
Feb 23, 2023 03:46 AM
smitty5150
Nov 2, 2013 06:44 PM
einzelherz
Aug 26, 2013 06:41 AM
msnewman
Nov 9, 2008 10:42 AM
TheIntegraGuy
May 15, 2003 06:18 AM
