Quick Headgasket question....
Old Sep 24, 2005 | 11:02 PM
B-B-K's Avatar
Default Quick Headgasket question....
I bought the GE Vtec kit for my LS-V before I knew I had to bore out my block, so I got the headgasket for a 81mm bore. But now that my block is going to be 81.25, am I going to have any problems with the .25mm bigger bore?
Thanks
Matt
Old Sep 25, 2005 | 12:35 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Quick Headgasket question.... (B-B-K)
you should be fine, the stock gasket is almost 82mm's
Old Sep 25, 2005 | 01:48 AM
No_Fear's Avatar
Default Re: Quick Headgasket question.... (PURPLETERROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR &raquo;</TD></TR><TR><TD CLASS="quote">you should be fine, the stock gasket is almost 82mm's</TD></TR></TABLE>
Old Sep 25, 2005 | 08:14 AM
onefstek's Avatar
you should be fine.
Old Sep 25, 2005 | 11:32 AM
DonF's Avatar
Default Re: (onefstek)
No.1 you should be fine. No. 2 why doesn't anyone call or E-mail the mfg. to get the correct answer.
reyesb25
Jan 21, 2009 08:07 AM
juanb
Jul 7, 2007 07:10 AM
92HB_HB
Mar 18, 2005 05:25 AM
Merilious
Aug 12, 2004 12:00 PM
senpai
Jun 17, 2003 05:39 PM
