b16/ b18 head...
Old Mar 1, 2002 | 02:17 PM
speedillusion's Avatar
New User
Default b16/ b18 head...
here's the setup i'm planning:
crvtec, type r intake manifold/ gsr intake manifold, itr exhaust manifold/ gsr, gsr tranny...
now, my question is... if you were doing this setup, would you want the b16 head or the b18? anyone have this setup?
i've done a few research on this. i just want people's opinion.
Old Mar 1, 2002 | 05:35 PM
Malice's Avatar
New User
Default Re: b16/ b18 head... (midnitekreeper)
b16 head is better flowing according to alot of peeps on here. i'd go that route
Old Mar 1, 2002 | 08:32 PM
rainforest's Avatar
Default Re: b16/ b18 head... (MaliceGSR)
b16a head 5.25% better flow rate due to the bigger combusttion chamber 42.7cc's. but if you need a little more compression go with the gsr it produces .2 more compression then the b16a head due to the smaller combustion chamber.
[Modified by rainforest, 5:33 AM 3/2/2002]
Old Mar 2, 2002 | 02:04 AM
X2BOARD's Avatar
Default Re: b16/ b18 head... (rainforest)
Yeah, the B16 head will net you about a .2 point loss in compression, but it is a better flowing head as compared to the b18, and the Type R manifold bolt up will not require any modification to the B16 head. You'll definitely not want the GSR intake manifold... even the B16 manifold would be a better choice. You will want run larger injectors tho.
[Modified by X2BOARD, 11:06 AM 3/2/2002]
slowB20ej8
May 19, 2008 12:19 PM
eternalhonda
May 23, 2005 06:39 PM
OreoEF8
27
Aug 20, 2004 10:16 PM
EFin' Kyle
Jul 26, 2004 10:09 PM
kimo98GSR
Sep 24, 2003 08:39 AM
