WHAT ECU IS BEST FOR D15B ENGINE?
Old Sep 24, 2005 | 04:11 PM
scarface50370's Avatar
Default WHAT ECU IS BEST FOR D15B ENGINE?
Old Sep 24, 2005 | 04:23 PM
brockscivic's Avatar
Default Re: WHAT ECU IS BEST FOR D15B ENGINE? (scarface50370)
P28 or P08 but i doubt you can find one...
get a P28 and run the vtec wires, its a hell of alot easier
Old Jan 23, 2006 | 04:48 AM
bmw626's Avatar
Default Re: WHAT ECU IS BEST FOR D15B ENGINE? (brockscivic)
will the p28 run fine in the car? or will it run rich or idle funky or anything? I am getting a d15b soon and a greddy turbo kit and it comes with a crome pro tuned p28 and i wanted to know if that will work or not or if i will run into problems
Old Jan 23, 2006 | 04:49 AM
DJ_SaNdOz's Avatar
Default Re: WHAT ECU IS BEST FOR D15B ENGINE? (bmw626)
The P08 is best, but the P28 works just fine.
Old Jan 23, 2006 | 05:17 AM
bmw626's Avatar
Default Re: WHAT ECU IS BEST FOR D15B ENGINE? (DJ_SaNdOz)
cuz i was going to swap in a d15b and i was told i can just use my z6 wiring harness and just change out my o2 sensor for the 4 wire and just use my soon to be crome pro p28 but i just want to make sure it works at full potential before i start shelling out money on my car again
Old Jan 23, 2006 | 05:31 AM
Stars's Avatar
I'm a Jackass
p28 is good
Old Jan 23, 2006 | 10:03 AM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scarface50370 &raquo;</TD></TR><TR><TD CLASS="quote">WHAT ECU IS BEST FOR D15B ENGINE?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz &raquo;</TD></TR><TR><TD CLASS="quote">The P08 is best, but the P28 works just fine.</TD></TR></TABLE>
X2 IF you get the VTEC version of the D15B, there are three versions that I know of, possibly more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmw626 &raquo;</TD></TR><TR><TD CLASS="quote">cuz i was going to swap in a d15b and i was told i can just use my z6 wiring harness and just change out my o2 sensor for the 4 wire and just use my soon to be crome pro p28 but i just want to make sure it works at full potential before i start shelling out money on my car again</TD></TR></TABLE>
Is this a trick question??
your Z6 harness has a 4-wire O2 sensor all ready.
Your Z6 runs off the P28 from the factory.
Once chipped the P28 can run any engine from a D15B to a H22, it's all on the map programmed into it.
Old Jan 23, 2006 | 03:14 PM
bmw626's Avatar
Default Re: WHAT ECU IS BEST FOR D15B ENGINE? (Relic1)
idk anything about ecus or conversions or basemaps or datalogging or any of that crap, all i know is that the d15b is a jdm z6 and i was told by a guy to run my z6 harness on the d15b and just swap out the o2 sensors.
Old Jan 23, 2006 | 03:22 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmw626 &raquo;</TD></TR><TR><TD CLASS="quote">idk anything about ecus or conversions or basemaps or datalogging or any of that crap, all i know is that the d15b is a jdm z6 and i was told by a guy to run my z6 harness on the d15b and just swap out the o2 sensors.</TD></TR></TABLE>
yes run the Z6 harness/ECU/O2 and you will be fine.
Old Jan 23, 2006 | 03:28 PM
mattssi's Avatar
The d15b isn't a jdm z6. the z6 is a 1.6, and the jdm d15b is 1.5 obviously. They did make a 1.5 vtec that shares alot of attributes with the z6... But tecnically if you were going to mak e acomparison like that, you should just call it a zc. which is a jdm 1.6 vtec sohc... but also a 1.6 non vtec dohc. Damn jdm. And you could also use a po6 but it doesn't have vtec. Does your 1.5 have vtec?
Old Jan 23, 2006 | 04:13 PM
bmw626's Avatar
Default Re: (mattssi)
my mini-me has vtec yes, the car i have is an EX but the ******* i bought it off of were running a p28 with a d15b7 so i just swapped the head out
creizlein
Engine Management and Tuning
14
Nov 8, 2016 06:24 AM
dr@ke
15
Oct 27, 2006 09:46 PM
haitian1
11
Feb 5, 2006 10:04 AM
jspecPR26
Jun 25, 2005 12:16 PM
Jasper_db1
Feb 5, 2004 04:18 PM
