Whats with my timing belt???
Old Sep 24, 2005 | 12:43 PM
impr323's Avatar
Default Whats with my timing belt???
Well my crank pulley bolt snapped in half a few weeks ago so I replaced the bolt, pulley and accessory belts. Well today I was cleaning my engine bay and noticed that the belt was sitting about 1/8 off the gears. I was actually able to push it back onto the gear by hand (with a little force). It doesnt really look like its digging into the cover though (if it is, its a little). Do you guys think it could be my tensioner??? I didnt have this problem prior to my crank pulley incident. If it is the tensioner, can I replace it without removing the crank pulley or the D/S engine mount???
Old Sep 24, 2005 | 01:41 PM
ThatsMyEG's Avatar
Default Re: Whats with my timing belt??? (impr323)
Yeah you can do it without removing the mount its actually pretty easy if you don't have P/S & A/C stuff in your way, all you need to change is the tensioner spring unless the tensioner its self is jammed or something..
JDM_SOHC
27
Sep 28, 2009 09:05 AM
SI89HATCH
May 21, 2009 06:37 PM
dfabulous
10
Dec 9, 2007 11:00 PM
spyderracing
Sep 25, 2004 03:38 PM
MLogan
Jun 10, 2003 06:07 PM
