resetting tdc question
Do I have to remove the crank pulley to get to the timing belt tensioner? My belt is off a tooth or so, and I just need to set the cam gear to tdc, then get the timing belt off the cam gear so I can set the crank pulley to tdc.
Re: resetting tdc question (spyderracing32)
No, you dont have to remove the crank pulley.
There is a plug in the lower timing belt cover. Pull it out and you will see the 14mm bolt for the tensioner.
*Edit- Luserkid beat me to it.
wk9k
03-13-2012 05:45 PM
JDM_SOHC
27
09-28-2009 09:05 AM
LoudLude
01-31-2006 05:21 PM
