Turbo kit help for 92 DX 4dr
i am going to order a greddy turbo kit for my civic and it clearly states in the description that it is a complete install but i dont see a wastegate anywhere in the kit, is it internal? and do i need a boost controller for a base kit like this or a boost gague since the boost is preset? any help would be great
http://www.sportcompactonly.co...3&l=2
thats the link, its the standard greddy non-intercooled kit if anyone can give a list of all parts needed for a non-intercooled kit i new to this and i plan on doing all of the work myself
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youdontneed2cams »</TD></TR><TR><TD CLASS="quote">its only 1245 for the 92-95 civic i sent the wrong page
</TD></TR></TABLE>K, that's more like it.
Another issue you're going to have is that it uses EManage. It's a good program, but it's meant for the D16Z6 motor.
You could probably run it with little problems, but the fuel will probably be off a bit, especially in high RPMs when it's expecting to be in VTEC.
You might want to look into a kit that includes an intercooler so you don't have to worry as much about heatsoak.
With this kit I would reccomend you get a boost guage, but a boost controller isn't necessary. A boost controller would only be necessary if you wanted to up the boost. I don't know how high of boost that EManage supports. I know your stock map sensor will only support up to 10psi, though.
Guest
Posts: n/a
the greddy kit includes EVERYTHING need to boost. i have it and i also recommend getting a intercooler, bov, and boost gauge. i bought the greddy intercooler kit thats made for the 92-95 civics and the greddy turbo kit. you will be fine running the e-manage on a d15b7.
GoFastHappy
Mar 17, 2004 09:57 PM
