B16a Idling low under 500 RPM
My B16a at a stop idles from 1000 to around 200 RPM. When it gets close the 200 RPM it feels like the car is going to stall but it doesn't, it just shakes my car like crazy like it is stalling. I changed the injectors, spark plug wires and spark plugs and it helped a little, but still idles to low.
dude i had this same exact problem on my dohc zc... sometimes it would idle perfect sometimes it would act up and idle low. i replaced all of my vaccum lines and that fixed it. i had a leak in one of them. cant remember which one. just replace them all let us know if this fixes it!!!! Also.. i dont know if this would help at all... I tightened my alternator belt at the same time.. maybe just a coincidence but thought that I would note that as well
Modified by ghost_ryder35 at 3:15 PM 9/26/2005
It sounds like the Idle air controle valve (IAC) isn't working properly , it could be a bad valve or The cooling system is low on coolent . If the CPU is reading the coolent at the wrong temp I may foul the signal to the IAC of the coolent temp sensor is bad. Check the coolent first
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TSM »</TD></TR><TR><TD CLASS="quote">It sounds like the Idle air controle valve (IAC) isn't working properly , it could be a bad valve or The cooling system is low on coolent . If the CPU is reading the coolent at the wrong temp I may foul the signal to the IAC of the coolent temp sensor is bad. Check the coolent first</TD></TR></TABLE>
He may be right.
First of all, DON'T MESS WITH THE THROTTLE CABLE just yet!
It's a band-aid solution, if it's something else than you just mess it up even more by adjusting the throttle
Check your oil. If it's some what chocolate-milk, cremy like then it is the head gasket for sure.
Otherwise, it can be bad dizzy
I never had this problem myself so i can't tell you what's up right off the bat but you should keep trying these suggestions..
He may be right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">clean the IACV.</TD></TR></TABLE> This could vary well solve your problem
aflyingpanda
Jun 5, 2013 02:36 AM
Never had a problem since. :D
