95 Si brake is really weak
Old Sep 23, 2005 | 05:29 PM
RedGSR's Avatar
Default 95 Si brake is really weak
I have a 95 Si. The brake is a little low and it is really weak. I have to slam on the brake really hard to stop the car. It is impossible to brake remotely close to locking up the tires.
disk and pads are new. Fluid are new.
What could it be?
Old Sep 23, 2005 | 05:31 PM
taney's Avatar
did you try to bleed the brakes?
Old Sep 23, 2005 | 05:35 PM
RedGSR's Avatar
Default Re: (taney)
yes... that's why I have new fluid in there.. totally flushed
Old Sep 23, 2005 | 05:42 PM
BloodPressure's Avatar
Check your proportioning valve for leaks or blockages.
Old Sep 23, 2005 | 07:30 PM
taney's Avatar
Default Re: (RedGSR)
it could also be your master cylinder .. you should take off the lines and see if they pump right ..
Old Sep 23, 2005 | 07:57 PM
upgraded's Avatar
you might want to look over your rubber brakelines and see if there are any signs of wear or bulges. the rubber could be wearing and flexing under braking causing your soft pedal. I had a similar issue a while back and replaced mine with goodridge stainless. huge difference, well worth the money. just a thought.
myenoodle
Mar 23, 2019 01:47 PM
hteg12
Jul 18, 2013 05:13 PM
offshore
10
Dec 11, 2011 05:24 PM
dave181
Feb 5, 2009 06:01 PM
