taking head off, any advice?
Old Sep 23, 2005 | 03:34 PM
EFin' Kyle's Avatar
Default taking head off, any advice?
ok i started to take my b16 head off and i noticed i cant get to the bolts under the header so i was going to take the head off with the top half of the header with it. should i do this or what? any help advice techniques are greatly appreciated
-Kyle
Old Sep 23, 2005 | 06:05 PM
juice91si's Avatar
Default Re: taking head off, any advice? (H4 Project)
how can you not get to the bolts on the header?
Old Sep 23, 2005 | 06:40 PM
91 crx savage's Avatar
use a open end wrench
Old Sep 23, 2005 | 07:38 PM
krazie1's Avatar
BANNED
Default Re: (91 crx savage)
use a short extenison and u should be good
so u trying to remove this engine on ur own Kyle
u should of called me up bro u know I am down for sure
Old Sep 23, 2005 | 11:30 PM
EFin' Kyle's Avatar
Default Re: (krazie1)
ok i can get to the bolts but i cant get the socket on the bolt straight. eventually i went under the car more and got ti on but cant take those bolts off. they are really on there. so i sprayed all purpose lube and am letting it sit for a bit and spraying a bit more tomaro morning. also when removing the engine what do i do with the wiring harness? do i unplug it from the ecu and slide it through the firewall and leave all sensors and everything plugged in?
Old Sep 24, 2005 | 03:10 AM
99teggsr's Avatar
Default Re: (H4 Project)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H4 Project &raquo;</TD></TR><TR><TD CLASS="quote">ok i can get to the bolts but i cant get the socket on the bolt straight. eventually i went under the car more and got ti on but cant take those bolts off. they are really on there. so i sprayed all purpose lube and am letting it sit for a bit and spraying a bit more tomaro morning. also when removing the engine what do i do with the wiring harness? do i unplug it from the ecu and slide it through the firewall and leave all sensors and everything plugged in?</TD></TR></TABLE>
you can take the head off with the top half of the header still on. You can also leave the intake manifold on also.
Before removing the engine unplug the miniumum amount of harness's so you can take the engine out and still have most of the harness plugged onto the engine. I believe there are a few connectors on the left and right sides of the engine bay right near the shock towers. Is the engine harness already modified to fit the b16 ? If not then take the harness off and let rywire do it, or do it yourself.
Old Sep 24, 2005 | 09:14 AM
EFin' Kyle's Avatar
Default Re: (99teggsr)
yeah it was modified for a b16. ok how do i remove the axels? my neighbor has pulled motors but not FWD. so i only need help with the axel removing. thanx for all the ehlp so far guys i really appreciate it
-Kyle
xiaogou
Apr 7, 2007 12:47 PM
lilpastrana
Oct 18, 2006 03:30 PM
Liquidgsr
Mar 7, 2005 09:17 AM
yellowbuffalo
Jan 1, 2003 06:06 PM
quikrpm'z
Jul 9, 2001 09:43 AM
