car won't fire the injectors
Old Sep 22, 2005 | 09:48 PM
SLR ef9's Avatar
Default car won't fire the injectors
doing swap 91 dx odo to obd 1 ls wiring done put the ecu won't fire the injectors with obd 1 ls ecu put it works with a 0bd 1 p13 if anyone has any idea's please throw them out need help as soon as possible thanks in advance.
Old Sep 24, 2005 | 09:41 AM
SLR ef9's Avatar
Default Re: car won't fire the injectors (SLR ef9)
anyone have any idea's of wnat it could be
Old Sep 24, 2005 | 10:33 AM
Flashmn's Avatar
Are the injector ohms correct?
Old Sep 24, 2005 | 03:20 PM
BuddhaSiR's Avatar
Default Re: car won't fire the injectors (Flashmn)
check your wiring. Your car probably had a TBI(throttle body injection). This setup only has 2 injectors and is wired differently to the ecu. OBD1 has 4 wires going to pins A1(inj. 1), A2(inj. 4), A3(inj. 2), and A5(inj. 3).
Old Sep 24, 2005 | 11:43 PM
SLR ef9's Avatar
Default Re: car won't fire the injectors (BuddhaSiR)
i double checked the pins in the ecu they are correct the car runs with a p13 so i don't understand why i does'nt run with a p75
Old Oct 4, 2005 | 11:42 PM
SLR ef9's Avatar
update car ran with a p28 tryed 2 different ls ecu's neither works need help bad
Matthewhughes
29
Aug 5, 2014 03:18 PM
89hatcher
Apr 5, 2009 06:28 AM
revtech motorsports
Mar 22, 2005 03:03 PM
A1
Jun 21, 2004 01:05 PM
X arkangel x
Apr 17, 2003 12:00 PM
