need help with fuel pump wiring for civic!
Old Oct 5, 2005 | 12:11 AM
l_v_l's Avatar
Default need help with fuel pump wiring for civic!
took out my fuel pump and tested it, works fine. I put it back into my car, connected the wires, turn on the ignition, nothing. sometimes it works, sometimes it doesn't. i thoght it might be ground wire, so i connected a ground wire directly from the battery. it's not that. Is there a fuse for the fuel pump or something like that? where does the other wire (yellow with green stripes) connect to? what do you guys think? need help asap.
Old Oct 5, 2005 | 01:02 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: need help with fuel pump wiring for civic! (l_v_l)
Sounds like its a bad power connection. Trace the wire if your motivated enough, or you could just find where it connects up front and test that. Diagnosing electrical problems like that just suck ***.
LS-VTEC-TURBO-EF9
Sep 8, 2013 03:24 PM
RICE POLICE SIP
Apr 21, 2010 03:26 PM
Bond
Oct 5, 2009 05:37 PM
h23vtec_dc2
Oct 24, 2007 06:13 PM
B18C-RnVA
Dec 27, 2002 06:26 PM
