Distributor Question
Old Sep 22, 2005 | 09:39 PM
hondaluva's Avatar
Default Distributor Question
I've got a 96 ls integra with ls vtec using the stock short block and wiring harness with vtec wires added. I'm using a 99 si head. Do i need a obd2a or obd2b dizzy or can i just use any dohc vtec dizzy as long as the plugs match. I need help on this one.
Old Sep 22, 2005 | 11:10 PM
mmuller's Avatar
Mad Scientist
Default Re: Distributor Question (hondaluva)
dizzy are the same on obd2's, you can make a obd1 dizzy work if you match up the wires.
but yeah your ls dizzy will work if you chop one of the legs off, or any obd2 dizzy for plug and play
Old Sep 23, 2005 | 06:16 AM
hondaluva's Avatar
Default Re: Distributor Question (mmuller)
thanx i would use the ls dizzy but it is dead to
Old Sep 23, 2005 | 08:47 AM
Katman's Avatar
using the LS dizzy is g h e t t o and it won't last.
But as mueller says, you can use any 96-01 B-series VTEC dizzy on your LS/VTEC.
mapa1229
Jan 22, 2011 04:58 PM
95GSRTT
Apr 11, 2005 01:25 PM
ernald711
Mar 30, 2005 08:24 PM
Big_S
Sep 7, 2004 08:17 PM
91hatch_on17's
Jun 25, 2003 10:26 PM
