ls distributor ?
Old Jan 21, 2011 | 08:45 PM
mapa1229's Avatar
Default ls distributor ?
so i was told...all distributors are internally the same...
my question is...can i take out my ls dizzy abd put it in a gsr dizzy shell?
Old Jan 21, 2011 | 08:56 PM
91_LS's Avatar
Default Re: ls distributor ?
All distributors are not the same inside. What year GSR do you have?
I know the OBD0 ls one is the same as the gen 1 tegs. If its OBD1,than it should work,but IDK. If its OBD2,no the parts won't fit.
Old Jan 21, 2011 | 10:18 PM
jl2218's Avatar
OBD1 AND OBD2 guts are the same.
You can only use VTEC with VTEC or non-VTEC with non-VTEC
Anatomy of a B-series Distributor
Old Jan 22, 2011 | 05:46 AM
94EG8's Avatar
Seagull Management
The only thing you can't interchange between vtec and non vtec distributors is the shaft/bearing assembly and the actual housing. CYP/CKP/TDC sensors are all the same as are the coil and igniter between all OBD1 and OBD2 D and B-series distributors (except HX coupes with hitachi distributors)
Old Jan 22, 2011 | 04:11 PM
mapa1229's Avatar
i have a 92 ls distributor, and im gonna be putting a 96 gsr.
Old Jan 22, 2011 | 04:58 PM
94EG8's Avatar
Seagull Management
You can do that, just swap the electronic stuff, keep the mechanical guts. the plug(s) will be different so you'll have to swap them (either depin or cut and splice)
carlossolorzano
Sep 4, 2010 06:24 PM
D-rush08
Sep 7, 2006 10:08 AM
ernald711
Mar 30, 2005 08:24 PM
Audi A4
Sep 15, 2003 09:26 AM
91hatch_on17's
Jun 25, 2003 10:26 PM
