looking for base map for crome?
anyone have a base map similar to my set up? i already posted on http://pgmfi.org/ so now i am trying here...
my set up:
b18c1 gsr bored and stroked to 2.0L w/ block guard
full blue print compition head work from alaniz
jun 3 head package cams, retainers etc...... cams are :GUNDRILLED:
12-5-1 comp. -^- dome pistons
twm 50 mm itb's
carillo rods
buttom end is blue printed, balanced and knife egded
smsp headers
no cat straight pipe 2.5' to es oval
rc 310cc injectors
p72 ecu with pro-crome
not sure if u need more info, but i need a base map for that set up to get my car out my house to the dyno shop to see what numbers i get out of it
thnks for the help in adcance, and u need more if let me kno but i think that should be enuff for a base map
my set up:
twm 50 mm itb's
carillo rods
smsp headers
rc 310cc injectors
either need a chip with the program burnt on it i will pay or a base map sent over..... will pay need to dyno this bitch already
i think the car's timing is off.......... someone told me when u get the basemap it will correct timing is this tru? or do i have to correct the timing first then install and turn the car on
set timing on the Dizzy to 16 degree's then it will go by the Maps on the basemap. i always set my dizzy to 16 degree's or.. if your Basmap starts out at 17 degree's then set the dizzy to 17 so that its accurate all the way through the RPM.
sewokozak
Engine Management and Tuning
Aug 9, 2018 02:08 PM
