best cam for 85mm 12.8-13.1 compression type r b18c5 head
Old Sep 22, 2005 | 11:49 AM
krystianitr's Avatar
Default best cam for 85mm 12.8-13.1 compression type r b18c5 head
looking to buy cams soon would like to know which cams you guys think would give me best power from 7k to 9500krpm?
THX
Old Sep 22, 2005 | 02:22 PM
Rocket's Avatar
Default Re: best cam for 85mm 12.8-13.1 compression type r b18c5 head (krystianitr)
I would do more research on cylinder head prep. Look up MAX_CFM / RLZ .
Most cams are pretty close in power and the right choice of cams is highly dependant on the valve job / head flow characteristics.
Old Sep 22, 2005 | 04:05 PM
itralex's Avatar
Default Re: best cam for 85mm 12.8-13.1 compression type r b18c5 head (Rocket)
my setup is pretty similar to yours
12.6cr 85mm ITR Block with Portflow head and I run Rocket's M22x
Old Sep 22, 2005 | 05:19 PM
ShaunRR's Avatar
HT White Ops
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">I would do more research on cylinder head prep. Look up MAX_CFM / RLZ .
Most cams are pretty close in power and the right choice of cams is highly dependant on the valve job / head flow characteristics.</TD></TR></TABLE>
Old Sep 23, 2005 | 05:22 AM
Default Re: best cam for 85mm 12.8-13.1 compression type r b18c5 head (itralex)
better cams mx22 or skunk2 stage 3 or Buddy club IV to run my set up??? I have ITB TWN 52mm too
THX guys
Old Sep 23, 2005 | 04:43 PM
ShaunRR's Avatar
HT White Ops
Community Builder
No one cam is better than another. Each just produce different characteristics in different motors.
Old Sep 24, 2005 | 02:50 PM
darrinbrewer's Avatar
Default Re: best cam for 85mm 12.8-13.1 compression type r b18c5 head (rochesterricer)
https://honda-tech.com/zerothread?id=1292294
there's my dyno and setup running sk2 stage2s
Old Sep 24, 2005 | 02:55 PM
DonF's Avatar
Default Re: best cam for 85mm 12.8-13.1 compression type r b18c5 head (darrinbrewer)
7500-9500 The June4's or Skunk Pro3's.
Old Sep 24, 2005 | 11:33 PM
I have now skunk2 stage 2,now I need more agressive skunk2 stage3 or maybe crower stage 3 ,Mx24??Which is better for set up
2L and ITB
THX
Old Sep 25, 2005 | 08:05 AM
DIFFUT'S INC.'s Avatar
ill say some toda C ,skunk 3' or pro 2 or some m22 they all on the same boat
Muckman
Apr 7, 2012 06:56 AM
sluggo
Jan 7, 2006 04:48 PM
jfingers
Jan 10, 2005 01:44 PM
Red99CivicSi
Mar 2, 2003 07:32 AM
TmeX05
Dec 29, 2002 09:55 PM
