OBDII - OBDI Coversion
Old Sep 22, 2005 | 09:42 AM
jetlude's Avatar
Default OBDII - OBDI Coversion
Hi Gus, Just wondering if you could give me some information regarding an engine swap I am about to do.
Any help is appreciated.
This is my set up.I want to put my sleeved 92 H22a into a 98 Accord (presently F20B) and I want to keep it OBDI. I have the OBDI P13 ecu and would like to use it with the OBD2-1 harness adaptor. The part I am not sure about is hooking up my obd1 distributor since it has the tdc/ckp sensors built in to it . I was told that these sensors are located in the oil pump are on an OBDII H22. How do I go about doing this part.
Thanks
Old Sep 28, 2005 | 03:15 PM
80mcfukdtp's Avatar
Default Re: OBDII - OBDI Coversion (bradboy)
put gravy on it
Old Sep 28, 2005 | 03:36 PM
philadd's Avatar
https://honda-tech.com/zerothread?id=1237137
It's for a 5th gen, but it should be very very similar, if not the same. You'll need to scroll down a bit for the obd2 - obd1 conversion.
Old Sep 28, 2005 | 05:37 PM
Snoochie Boochies's Avatar
From: behind the dumpster, w./your bitch, w./your bitch
Default Re: OBDII - OBDI Coversion (80mcfukdtp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 80mcfukdtp &raquo;</TD></TR><TR><TD CLASS="quote">put gravy on it
gravy huh.... does that work? like brown gravy? granny makes that for thanksgivin' i put on mashed taters and its so yummy!
i want mashed taters and gravy....
Redprelude98
Jan 9, 2009 11:46 AM
H22@
Jun 10, 2008 10:20 AM
96accordexproject
Mar 17, 2008 10:31 AM
Adam West
May 8, 2006 03:47 AM
crxhybrid85
Mar 7, 2005 03:51 AM
